  • Replies 433
Posted Images
marrk: please confirm these braided lines are rated for track use.
can you please confirm that the 780 degree rated pads are the 750's you're selling? I thought A1RM were rated to around 580 degree's?
cheers,
daniel
cheers,
daniel
Hi Daniel,
Yes the braided lines are rated for track use.
A1RM are defintaly rated to 780 degrees.
Feel free to call BrakeWest to confirm.
Cheers
G'day interested in the braided lines i have a 260RS stagea, you mentioned earlier in your thread that only thr fronts will fit, why is that? if someone has already answered this question earlier in the thread im sorry its just a rather long one now.
Cheers
Cheers
Hey Mate,
When BW received a sample for the stagea lines, they only received the fronts, not the rears.
Cheers
nope. i work in a place that sells crash parts, some of the stuff is adr compliant but not approved. there's a big difference. if they are adr approved then they are 100% legal, if they don't have approval they're not street legal. thats why i asked.
I hope they are ADR approved..... I just bought a set. If not insurance with not cover vehicle in a crash.
You learn something new every day.
According to BW, these hoses are ADR approved. Each hose has their own set of ADR approved rubber connectors, and their machine to make the hoses has its own set of ADR numbers too.
Feel free to call BW to ask.
nah thats cool, if they have the rubber rings with the approval no. then i'm cool with that. will need a set next week if all goes to plan :thumbsup:
Edited by dougs
Just arrived now :(
Look good! Thanks Mark!!Great service! you have a new trader rating :)
finally gave these puppies a work out at two sprint days
f**king awesome!!!!!
that is all!
Hey mate,
Can the braided hoses be used on an R32gtr with 34gtr brembo brakes?
Yeah no problem.
They'll be just standard 32 gtr lines. They might need different end fittings. I'd need to confirm with BW.
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
