  • Replies 433
Posted Images
got the lines fitted last week i can acctually say there is quite a big difference in brake peddal feel
no more spongy fill to it nice and solid cheers mark very happy thanks mate.
Cheers
Allan.M
What are the brake pads like pad vs rotor wear?
The high performance pads (500 degree) are equivelent performance-wise to Bendix Ultimates, but should last roughly twice as long. The high performance pads also produce about 90% less dust then the Bendix Ultimates.
The track day pads (750 degree) can handle approximately 100 more degrees than the EBC greens. They will also last roughly twice as long as the EBC greens and have about half the wear and dust.
Obviously all these figures depend on your driving style, but these are a rough estimate.
If anyone has anymore questions, please ask.
Cheers
Mark
Braided brake Lines --- is the group buy still going?
When is the last day?
Also how long does it take for delivery?
I have track day end of nov (this month) .. so i would need it soon
Also is this a bolt on type job?
Anything else required to fit ?
cheers mate
Edited by siddr20
cheers mate
Hi siddr20,
I'm taking orders for this GB as we speak. GB closes at the end of this month.
Hoses are generally being shipped the day after payment is received.
These are a direct replacement for your old hoses, so just take off the old ones and put the new ones straight on.
All you'll need to do is bleed the brakes slightly once you put the new hoses on. Fairly easy to do.
If you have anymore questions, just ask.
Cheers
Mark
Hi Mark,
i see now you have the Stagea fronts for the braided brake lines. Are they the same as the R33Gtr? how about the rears? Is the stagea for a RS4s or 260rs? Will they be the same? Let me know.
Do you have anything for the the pads? Its equilvalent to the R33GTR brembos.
Hi Mark,
Hi stasis,
From memory, from what BrakeWest said, the hoses are similar to the 33 GTR. The rear hoses are a pain in the a$$, that's why BW aren't doing them. It involved changing changing some fittings on your car from imperial to metric and was more trouble then its worth. This was all for a 260RS, not sure about the RS4.
For pads, BW don't have anything available for Brembo systems unfortunately. I was using the K750's with my standard GTR brakes, but since i put Brembo's on the car, I've had to settle for EBC's.
Cheers
Mark
Hi stasis,
Cheers
Mark
ok thanks
Hi stasis,
Cheers
Mark
ok thanks
Hi stasis,
Cheers
Mark
ok thanks
Hi stasis,
Cheers
Mark
ok thanks
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
