I would like to put my name down for:
GTR 32
Package 2:
1 x Full set of ADR approved braided hoses
1 x K500 Front Pads
1 x K500 Rear Pads
$330 Delivered
Please PM payment details via Credit Card
  • Replies 433
Posted Images
GTR 32
Package 2:
1 x K500 Front Pads
1 x K500 Rear Pads
$330 Delivered
PM Sent re: credit card payment
Just put through the payment and looks like i may get em today before i leave for work coz im local! ...otherwise tomorrow morning. w00t! MINT!
Will reply back when i get em on and let others know how it is....
EDIT:
Was delivered to my work by 2PM three hours after payment!!!! ....pitty i finished 5min beforehands :wave:
:wave:
For pads, BW don't have anything available for Brembo systems unfortunately. I was using the K750's with my standard GTR brakes, but since i put Brembo's on the car, I've had to settle for EBC's.
I've got QFM available for the Brembo, but I get them custom made so they're a bit more expensive though, looking at $150 for the HPX (I think you guys call it K500) and $175 for the A1RM (K750).
Still much better pads and value for money than anything else out there!
Yeah i think you can get them made up if you have a backing plate from another worn out pad.
I plan on doing the same thing when my EBC's run out.
If anyone is interested in getting pads custom made, I can always enquire with BrakeWest.
Cheers
Mark
Yep, inquire with Brake West and let us know. I was getting the backing plates by buying the cheapest pads available (in this case, Bendix GCT), and then stripping them and sending to QFM. If you've already got the backing plates it makes it a bit cheaper. Let us know what BW can do, or else, I'm fairly local to QFM, so might be able to be a few bucks cheaper as I save freight from Melb-Bris-Melb on the old backing plates...
I just got off the phone with BrakeWest. To send the backing plates to QFM, the plates need to be completely bare. A blowtorch can be used to clean them up.
Prices are:
K750 - $165 delivered
K500 - $140 delivered
Brakewest said they can't give a timeframe of how long it'll take to send the plates to QFM and back, so there are no guarantees there.
If anyone is interested, send me a PM.
Cheers
Mark
Prices are:
Nice...
I've sent quite a bit of stuff to QFM lately to get custom done, and generally been no more than 3 weeks tops. Have been a couple of exceptions though. Because the high performance QFM stuff only gets done on weekends, outside their normal production schedule, they can't change the oven settings until they've got enough pads to make it worthwhile.
I know this is your group buy, so I won't push the point, but if you can get a few people together I should be able to match brake west's price on those Brembo pads, WITHOUT the need to exchange pads, and have your car off the road for up to a few weeks...
Nice...
I haven't asked BW yet, but I'm pretty sure that if we rounded up say, 5 - 10 people, they'd be able to do better again on price. That price is just for a one sale.
If anyone is interested in getting K750 custom Brembo pads, let me know so we can get some numbers up and get a better price.
How easy are the brake lines to install yourself? Any pictures of them post-install? Do they add much "bling" to the engine bay?
Fairly to install mate.
1. Take off your wheels.
2. Unscrew old hoses.
3. Screw in new hose.
4. Bleed hose.
5. Repeat for each hose.
The GB will be closing this Sunday (25th November) for Christmas.
BrakeWest would like me to pass on their thanks to everyone who made a purchase.
This GB will re-open in Janurary next year.
:D
9 pages is a bit too much to read through - i want to know what the effective temp range of the pads are and also their coefficient of friction (both types)
Thats why all the important info is on the first post...
K750:
Operating temp: 0 degrees celcius - 750 degrees celcius
Cold friction Co-efficient: 0.40
Hot friction Co-efficient: 0.48
K500:
Operating temp: 0 degrees celcius - 500 degrees celcius
Cold friction Co-efficient: 0.41
Hot friction Co-efficient: 0.42
not all that info is on the first post but that answers the question :)
do you get papers with the lines that says its ADR approved, or is it stamped on that little grey insert the ADR approval numbers, or is it somewhere (something?) else?
Close enough :)
Yeah you get the insert which says they are ADR approved
Received my hoses today! ! !
I am very impressed with the quality of build and the custom black hoses with black end caps for my GTR are simply the best.
Thanks again Mark for your great service and a top product,
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
