Hey guys
Looking at getting some Tein type flex coilovers for my ecr33, is anybody here using them and if so what are your opinions/experiences with them? most people seem to be using Super Streets, but im not sure if they will go low enough for my liking, i want something that will just tuck the top of the tyre inside the top of the gaurds, and ofcourse they need to be smooth enough for street use but need to be good on the track aswell (i may start doing some track in the future), i think the spring rates that come with the type flex's are 6kg all round.
So basically im looking for some opinions on what the type flex's are like, any help would be really great.
Cheers :cool:
Edited by nizmo_freek
https://www.sau.com.au/forums/topic/177691-tein-type-flex/
I am using them in my 32 gts, so the result in the 33 can be rather different. For height adjustment, the fronts go pretty low (can tuck the wheels), the rears you have to un preload the springs to get less than a one finger gap. But, if you wish to dump the car, the springs/dampers are too soft, even if you preload the piss out of the fronts its still prone to frame smashing. But once you find the happy medium for height, they are a pretty good daily setup. Smooth enough that your kidneys dont explode, and stiff enough to keep the car level in corners. Again this is just my experience with my car, but I hope it helps.
Edited by 403_r32
https://www.sau.com.au/forums/topic/177691-tein-type-flex/#findComment-3245880
Cheers for the help mate, so do you know how much lower the type flex's can go compared to the super streets?, ive been looking for info and pics of r33's with them and cant seem to find any decent info anywere, if they can just tuck the tyres (im running 18x9 +30 on the rear with 255/35 and 18x8 +28 on the front with 225/40) then i will be happy, i dont want to go ultra low, just low enough so i dont have a gap between the tyre and gaurd.
Any further help would be really appreciated.
Cheers
https://www.sau.com.au/forums/topic/177691-tein-type-flex/#findComment-3249662
I've got Type Flex's on my R33 GTS-25T. Mine are set so that centre of wheel to gaurd is about 340mm all round. They have lots of room to go lower though. I'm sure you will be able to get them to sit as you describe.
I run 17x8 and 17x9's and have about 3-4cm from wheel to guard. I'm quite sure they could be adjusted much lower. Plenty of room on the coilover to lower more.
I think they are great for the street. Firm but not overly that it feels as your car is gonna fall apart. The car handles well too. They are designed as a compromise for the daily driver with track work in mind.
Another user on SAU a couple years back also recommended them to me when I posted the same question as you.
https://www.sau.com.au/forums/topic/177691-tein-type-flex/#findComment-3249789
Never been on track so couldn't really say. Have done lots of spirited driving on the road...twisty mountains..and find them more than sufficient.
There is little body roll and good feel over bumps. The only other R33 skyline i've driven with coilovers was a GTR with tein HA's. Felt much stiffer and harsher over bumps.
https://www.sau.com.au/forums/topic/177691-tein-type-flex/#findComment-3254749
  • 3 weeks later...
Hi mate
I have a set of Tein flexs on my R33 GTR and find them great and there is lots of room to slam it to the ground if req.
I like a bit of ground clearance for the front bar and had to raise it a bit but it still looks good just an inch between the top of the tyre and guard.
They can be a bit on the harsh-side on rough-lumpy roads roads and can bounce the car around but more than make up for it on smooth ones when its time to hit warp speeds.my mrs drives it and never complains about the suspension being harsh,i would call it very firm.
What transformed the handling and steering was getting Cusco adjustable arms (front and rear) and getting the wheel alignment set up correctly as you will have excessive camber after lowering and touchy steering(and brutal tyre wear,unless this is fixed).
hope this helped
https://www.sau.com.au/forums/topic/177691-tein-type-flex/#findComment-3289632
i dont know how much tein flex are worth but i had super streets in my s13 and they didnt go too low at all. I have HA's in my r32 now and they go lower but not that low still.
My brother has super streets in his s14a but he bought them from fulcrum and befor they even sent them they stripped them down, put on metal camber adjustable tops, scrapped the 5kg,6kg springs and got f8kg and r6kg springs and cut them (properly of course) and revalved it to suit the shorter stiffer springs. Needless to say after the dyno and all they cost him $2600 and they are the nicest coilovers i have felt out of any tien/hks etc. How ever HKS also go very low.
My opinion... id rather spend $1500 on HSD type R which have metal tops, full hieght and damper adjust, never heard a thing wrong and apparently they go very low. Then you have $1000 to buy the sway bars and front and rear camber kit... then you will handle even better than what an expensive set of coilovers will give. Personally i think HSDs are a good coilover
https://www.sau.com.au/forums/topic/177691-tein-type-flex/#findComment-3290194
Shit didnt relise i didnt update this thread, anyway my supplier sold the last set of flexs just as i went to buy them so i decided to get super drifts intsead, they are a model up from the flex's, come with 7kg springs front and read and have pillow ball top hats (the flex's dont come with top hats so you have to use the stock ones), the can go super low and ride nice and smooth (a little bumpy sometimes but nothing to complain about) ,they have transformed the car handling wise!! i can post pics on the shocks and with them installed on the lowest setting if anyone needs pics etc etc!
Cheers for the help anyway guys :wave:
https://www.sau.com.au/forums/topic/177691-tein-type-flex/#findComment-3290939
Im running type flex in my 34 and they can be lowered until the car is dragging its ass along the road, anyway with my whiteline swaybars the car handles great, the super drifts are are good coilover too.
https://www.sau.com.au/forums/topic/177691-tein-type-flex/#findComment-3291772
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
