I was asked by someone what I usually rev to thru each gear and when I told him about 4 grand, he said "all you R33 owners are the same! Why do you rev so high?"
When my car is cold I don't rev that high - i try not to use any boost at all...but during normal driving, i always rev to about 4 grand!
soooo what do you guys usually rev to?
ps i think I've used the word "rev" far too many times in this post :D
https://www.sau.com.au/forums/topic/1777-what-do-you-rev-to/
Guest | hype^ |
lol dam grim.. thats harsh.. especially when its cold..
well i only had my car for 5 days (it should be fixed in the next few days :D ) but i usually reved to about 2500-3000 just in normal suburban driving.. but when goin for a 'spirited' drive i usually go to about 5500 or 6500 in each gear... :D
https://www.sau.com.au/forums/topic/1777-what-do-you-rev-to/#findComment-33403
There is ONLY ONE import owner with a manual who doesn't worry me, and he's rarely on here. You lot are mad! Revving to 4000rpm all the time during normal driving! THEN you complain about fuel consumption... :lol: whyyyyyy. I think its because you are all so isolated and insulated from whats going on.
Unless gearing or conditions dictate otherwise, i shift at around 2000rpm now. Hot or cold. I used to go up to 3000rpm sometimes if i was in a bit of a hurry, to punch up a hill or something, but now im really povo (fuel), and plus, if im not going hard, its not fun anyway, just gonna wear the engine more.
funny thing is, the one import driver i mentioned has a modified Vspec. Cuts sick on track days though.
This is a pet peeve of mine, if you hadn't guessed.
P.S. Used to own a 20,000rpm roadbike, at 6000rpm it was still doughy as poop. :D
https://www.sau.com.au/forums/topic/1777-what-do-you-rev-to/#findComment-33585
I shift at no more then 3,000 when the car is cold.
I shift at around 4,000 to 4,500 for normal city driving.
I shift at around 8,000 to 8,750 when drag racing, depends on what gear I am in to how far I take it.
https://www.sau.com.au/forums/topic/1777-what-do-you-rev-to/#findComment-33615
hirisk:I shift at around 8,000 to 8,750 when drag racing, depends on what gear I am in to how far I take it.
Hey hirisk do you have stock internals in your car if so do they take that kind of reving easily cause with my GTR i have a big single and id love to remove the cut at 8000 to get a bit more from the turbo. When it only starts boostin at 5 i would like all the revs i can come across, thanks.
https://www.sau.com.au/forums/topic/1777-what-do-you-rev-to/#findComment-33883
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
