Was looking at some car web sites on the weekend and saw the new Evo X. Though this is a Skyline forum I thought with all Evo fan boys here that someone might have posted a thread. In case you haven't seen it yet I've posted some pics below. I don't know if it's just me but I'm seeing a lot of R34 GTR design elements here. Same type of nose and bonnet and pumped out square rear guards. What do you guys think? I'm thinking I could drive one of these if it looks hot in the flesh, I don't think pictures do it justice much like the R34's.
http://www.leftlanenews.com/mitsubishi-lan...volution-x.html
https://www.sau.com.au/forums/topic/177702-mitsubish-evo-x/
  • Replies 74
Posted Images
Everytime I see these topics come up I look at the pics and say yuk!
But they always seem to grow on me especially the VE HSV range.
I don't like the look of it at all really, the headlights and rims are only things i would say I like.
But I'm sure when i see one on the roads I'll be following it to check it out cause it's so hot.
https://www.sau.com.au/forums/topic/177702-mitsubish-evo-x/#findComment-3243893
eh i like it but then i dont. looks a little tougher than previous models, and draws away from the lancer(which is good. other models just looked like a lancer, which is why i couldnt bring myself to buy one), lights are cool.
just a little boxy, and there something about the front bar that isnt quiet right IMO.
https://www.sau.com.au/forums/topic/177702-mitsubish-evo-x/#findComment-3243921
the rear looks a little alfa romeo ish...
and is it bigger than previous models? like a legnum or whatever they are...
i don't think people buy evo's to have a burgundy car either, imo it will look much better in a traditionally more aggressive colour, black/white/red/etc etc
https://www.sau.com.au/forums/topic/177702-mitsubish-evo-x/#findComment-3244059
theres other links and images in an old thread here... http://www.skylinesaustralia.com/forums/in...0673&hl=evo
i know i would rather one of these then the gay new WRX
also there will be a cheapo version GSR or they may call it VRX here or ralliart cant remember which will be to compete with the std WRX.
https://www.sau.com.au/forums/topic/177702-mitsubish-evo-x/#findComment-3244337
I don't like the look of it either
R35 style front, RX8 style rear!!! in 4-door
yuck
they should just make a 2-door EVO and style it differently, bet it'll still sound like a sewing machine or tractor like most mitsi's
https://www.sau.com.au/forums/topic/177702-mitsubish-evo-x/#findComment-3244524
I dunno Ni. The most recent "spy shots" from the Ring I reckon the STi actually looks better. The EVO is starting to look very plastic, high and a bit dull now that it is moving from the prototype stylings and into the production stylings. Where as I reckon the Rex is looking quite WRC (even it if is a Xsara copy)
https://www.sau.com.au/forums/topic/177702-mitsubish-evo-x/#findComment-3244535
ew please tell me ur joking?
u have seen the new rex without the black hide me tape on right? official pics were released like 3 months ago... maybe more.
Looks like a Daewoo had sex with a mazda... or even a camry
Maybe the STi will look better... but still.
https://www.sau.com.au/forums/topic/177702-mitsubish-evo-x/#findComment-3245302
I like......But 80K...
Maybe with the dollar getting to 88 cents US.....we might get it for the price of the IX...65K..if i recall.
KEEP YOUR SKYLINES........LOL.......TURBO FUN AT A 1/5 of the price....
GTR32's will increase in value when this comes out. :D
Anyway..love to see it in real life..looked much narrower in the pics of old..
https://www.sau.com.au/forums/topic/177702-mitsubish-evo-x/#findComment-3245711
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
