Hey peeps i've got an r32 gtst with an rb20det. When i go to put my foot on it, it starts to spool but it also sounds like its leaking boost from somewhere as there's like a "pshhhhhh" noise and it seems like there's a little lack of power. Has anyone else experienced this or know what it could be?
https://www.sau.com.au/forums/topic/177709-rb20det/
what boost is displayed on your boost gauge?
do you know what a turbo sounds like?
11psi. which is what its set to. yeah this is a really loud shhhhh noise tho..doesn't sound like a spool unless i'm on crack and have got it completely mistaken..but it feels like i lose power
https://www.sau.com.au/forums/topic/177709-rb20det/#findComment-3244105
If you can see 11psi, then "if" there is a leak, it is after the turbo.
so being an RB, most probably a gasket leak at the turbo manifold.
My guess from this side of the monitor is that you have a bolt missing from the turbo to the manifold.
you might be able to just tighten replace and tighten it and it will go for a while longer.
"IF" there is a manifold leak, and you leave it, it will get worse as the whole in the gasket gets bigger.
eventually, it will start to sound like a lawn mower when idling.
"OR" you are most likely on crack and it's just the sound of an RB20 with exposed pod filter.
https://www.sau.com.au/forums/topic/177709-rb20det/#findComment-3246522
ok cool. i'll have a look. I think everyone may be right i think it is probably only the pod induction. I was just wanting to make sure because i'm selling it..i'm not the most technical minded person and sometimes i can be a bit thick
https://www.sau.com.au/forums/topic/177709-rb20det/#findComment-3246829
