rear speakers in a 2 door coupe don't really do much. I just use a pair of JVC 180W PMPO's for rear fill. The Focal splits up the front and the nakamichi sup do the hard work. I paid about 75 buck (or maybe less can't remember) for the rears.
https://www.sau.com.au/forums/topic/17773-rear-speakers/#findComment-368786
If your objective is just to maintain the factory stereo the most important thing is to make sure the new speakers drop straight in. I'm not sure about the R34 but my earlier Skyline uses 6"speakers that mount in a 130mm hole. You should be able to measure the hole from inside the boot. Listen to speakers in your price range and choose the ones that sound the most natural. Bright treble and detail are best left to your front speakers so go for something mellow in the rear.
https://www.sau.com.au/forums/topic/17773-rear-speakers/#findComment-368918
  • 3 weeks later...
Hey if u are looking for some cheap speakers that do a alright job, check out Jaycar's range. Nothing all that fancy but quite good for value. www.jaycar.com.au
Staff are usually pretty good, I once were replacing speakers in my old car, they let me borrow a speaker ot c if it would fit quickly, They guy just took my liscence so i wouldn't leave him.
The store i went to was on ipswith rd.
WOOLLOONGABBA
65 Ipswich Road
Cnr. Wilton Street
Woolloongabba QLD 4102
Ph. 07 3393 0777 Fax. 07 3393 0045
Mon - Fri: 8:30 - 5:30, Thu: 8:30 - 8:30, Sat: 9:00 - 4:00, Sun: 10:00 - 4:00
Queensland, Australia
https://www.sau.com.au/forums/topic/17773-rear-speakers/#findComment-409982
I disagree that the rears dont do anything or arent worth worrying about, i only had rears for a while and with a decent amp hooked up to them the noise hits you clearly and hard (in my r32 any way) i think this could have alot to do with the angle of the back window but my rears are my high end sound apart from the subs...i got some cheap 4" and tweets in the front running of the head unit till i find something small and decent for the front.....there is no room in r32's for good big front splits that dont require a huge pod to mount them in.
https://www.sau.com.au/forums/topic/17773-rear-speakers/#findComment-411087
I'm running a set of focals up front, and a nakamichi 12" sub in the boot, between them they cover the entire audible sound range (took a reading at the audio shop to proove it) so I didn't really need anything else, coz it would throw out the balance, I just needed rear fill. I would have kept my stockies if the damned paper cone POS hadn't started making noise.
https://www.sau.com.au/forums/topic/17773-rear-speakers/#findComment-411866
I'm in about the same position... got my sub in now, reasonable front splits, except the back ones keep buzzing and shitting me. JB-Hifi i saw had some 2 way 6" Pioneers for around $70.. they'd be ok - and they weren't even their "bottom of the range" ones.
Sales are on at the moment.. so grab them by the testicles and start calling out prices :mad:
https://www.sau.com.au/forums/topic/17773-rear-speakers/#findComment-411884
Guest RB20DET
I didnt bother with anything expensive in the rear..
i drove around with a front stage and subs for a while, and noticed the rear needed some filling, so i bought some $80 clarion coaxials. This does the job, i have my front stage MUCH louder than my rear, just have the speakers in the rear to fill the gaps. I wouldnt spend much money on it unless you are eager to please people who sit in your backseats.
https://www.sau.com.au/forums/topic/17773-rear-speakers/#findComment-411902
Sales are on at the moment.. so grab them by the testicles and start calling out prices :D
I agree with predator666, there are sales on at the moment and you should be able to get decent speakers at a good price...
https://www.sau.com.au/forums/topic/17773-rear-speakers/#findComment-413314
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
    • @Dose Pipe Sutututu I read your replies RE: R35 GTR MAFs, any ideal spots to put on? Obviously will need the adapter plate. Will be having a cross over intercooler fitted shortly, would putting it a bit before the TB be okay?
