Ever Thought "I wish I could tune my Power FC with a LAPTOP" GENUINE - FROM APEXERA (Apexi) - FC Commander Pro Software.
Software is in ENGLISH
Allows you to EDIT and SAVE your Power FC Tune on your Laptop.
$475!! FREE DELIVERY!!
Limited offer for SAU / NS Members
More software screenshots can be found at: http://www.accessauto.com.au/techpg1.htm
Comapatible with the following Models:
Part No. Serial
Nissan
414-N010 BNR34
414-N011 GTR33
414-N012 ECR33
414-N013 S14(1)
414-N014 SR2014
414-N015 SR2015
414-N016 SR2016
414-N017 SR2017
414-N018 SR2018
414-N019 SR2D19
414-N020 SR2D20
414-N021 SR2D21
414-N023 SR2D23
414-N024 SR2D24
414-N025 BNR34D
414-N026 GTR33D (GTR R32 and GTR R33 D-Jetro)
414-N028 BNR34L
414-N029 GTR33L (BNR32 and BCNR33)
Subaru
414-F003 GC8F
414-F005 GC8DL
Toyota
414-T006 SXE10
414-T007 ZT231
414-T008 ZW30
414-T009 J100A
414-T010 SXE10T
414-T011 J100M
414-T012 ZW30T
414-T013 SX10A
414-T014 SX10TA
Mazda
414-Z004 FD3S4
414-Z005 FD3S5
414-Z006 FD3S6
Honda
414-H003 AH03
414-H004 AH04
Mitsubishi
414-M001 CP9A6
414-M002 CP9A5
414-M003 EVO6D
414-M005 EVO5D
414-M007 CT9A7
414-M008 EVO7D
414-M902 D32AL
414-M905 D32AD
414-M907 CT9AL
414-M908 CT9AD
One interface does ALL of the above models! Please check you power FC part number / serial number before purchase to ensure comapatibitiy - if in doubt PLEASE ASK US.
Required system configuration:
OS: Windows 98, Me, 2000 Pro, XP (english)
PC: PC-AT comaptible, Pentium III 500mhz +, 256mb +, RS232C Port Required. (Has been used sucessfully with USB to RS232 converter - we can supply one for an extra $10 if required)
Browser: IE 6SP1 or above (internet connection required to install and register software - ADSL preffered)
Wow software that does not even let you reinstall it on the same PC. Even Microsoft isn't that barbarian.
With a mean time between failure of 4 years for an average PC, thats going to be an expensive PC crash when it happens.
could you please expand on the no reinstall thing, i truly think if you need to register it thats fine but if you cannot even reinstall it after a laptop failure or upgrade, that is trouble.
In response to concerns:
1. It does support R32GTR (Understanabley confusing - as the serial number on GTR 32 / 33 computers is "GTR33L")
2. FC Commander Pro CAN be re-installed - however - this is a process that involves issuing a new serial number from Apex - we have done this before, and it wasnt a problem. We do however ENCOURAGE people that this be installed of a freshly prepared PC / Laptop - to maximise its serviceability.
Hope this helps!
Hope this helps!
So what is the price of getting a new serial?
If the software is purchased through us and a new serial is required, there is no charge.
how much more dose this software do then the hand controller?
You can save and load data through your laptop
Edit Data
View full maps in there frame instead of scrolling
User friendly interface
  • 4 months later...
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
