  • Replies 175
confirmation to get 3 for me. thx :D
No problem at all.
Cheers.
I have just sent a PM to everybody that i can see has said they want one. Time to pay up!!!!
If you didnt get a PM let me know.
Its not too late if you still want one. (Again, let me know and ill PM you the details) Im trying to get a cut off date for This Thursday but it may need to be opened another week while people organise their payments etc etc.
I will let you know when the order is placed, and when the delivery of the units to me is expected.
Thanks guys.
Brad
so i was about to transfer the funds and realised i live in rockingham how much posting do u want if its doable to post it to me , wasnt sure if its to much trouble ill come pick it up of u some time but postage would be less in fuel lol .
matt :yes:
matt :yes:
I can arrange postage for you. I use Foxline couriers and it will be $6 postage per order to get to Rockingham. e.g 1 unit will cost $33 + $6 postage. 2 units will cost $66 + 6 postage. etc
Any problems let me know. When i have received them ill put up a post, then PM with your day time delivery address.
Cheers
Brad
Cheers
Brad
great, as well as sending and recieving orders i have to also send out a trillion fire extinguishers LOL :action-smiley-069:
Hey dude.. I was wondering how much would postage be to Sydney?
And how soon would I get them after Ive paid?
Only reason I ask is bcoz ive placed an order for a fireexthingusher from firstaidsales.com.au and havent heard or recieved anything from them.
And I need the fire extinguisher before the 23rd Aug.
:D
:D
Id be happy to organise it for you, but Freight would be no less than $20 which i think would make it too expensive. Are you sure there is no where else in Sydney it can be purchased from?
great, as well as sending and recieving orders i have to also send out a trillion fire extinguishers LOL :D
That is because you are Brad's Prank Monkey!
You will learn to love the job...
Dance Prank Monkey Dance!
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
