Perfect Shift?
hi i m and currently on mi ls. I cant seem it get into 2nd gear without grinding. i have tried everything including double clutching. it works but takes me too long. what is the secret? another way i tryed is to go 3000 revs then nutruel then drop to like 2100 and then engage but the motor lags by thie time i let it drop that low. what is the secret?
thanks
Are more seasoned drivers replicating this fault on your vehicle? Or have you tried to drive another car, and is it doing the same thing?
As people have said, its sounding more like a car problem than you. Double check. :D
since you are in gympie i could take it for a spin and see if it is the gearbox or just you. more than likely the box is a bit shagged tho. if it only does it from 1st to 2nd then it is more than likely the sychros. if it is every gear it could be low clutch fluid, damaged pivot bolt or fork, or just a shagged clutch.
probly about $1200 to fix at a guess. you will damage the syncro more but shouldnt damage anything else if u keep driving it, although it may be possible of chucks of metal break off. just dont use second where you can.
if you do get a new box though, or rebuild/fix this one, practice driving without the clutch before it gets done, can gain some good experience doing this, and its sorta like a way of driving without relying on syncros, but dont htink to deep into that without knowing how your gearbox works or it will just confuse you :thumbsup:
fark the clutch, just rev it right up each gear and quick shift :laugh:
but yea, sounds more to me like the clutch is not engaging fully. and you could actually try clutchless shifting to see if the clutch is the problem.
PS: you will probably get allot more crunching learning how to shift without a clutch though lol, i did. key is to just give the revs a nice blip and then slip it in.
EDIT: mybad didn't read the last reply :laugh:
Edited by deant1
also you should know that under the new qld laws you can't legally drive this car untill you have your opens, so don't be supprised if you get booked.
yer it says if it is owned by a direct family member you can apply for a exeption. so i will get mi mum to make her own the car then ill be right by the book.
Best answer thus far. Take this advice!!!
it is that if it is the ONLY family vehicle, or if it is an emergency, or if you have to drive it for work (if it is a company car).
so if your family has 2 cars then i doubt they will grant you permission.
plus you will have to display your p's, so pretty much every cop that sees you will pull you over.
besides, you are better of driving a shitter for the first few years, especially if you are going to go to uni.
 Share
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
