last friday there was an accident on the bridge in town...in stop/start traffic for a good hour...then as i left the bridge and traffic i noticed my steering had become extremly heavy and i had no speed reading (or odometer)
I had been brainstorming with a mate and we're out of ideas...the most logical reason we could come up with is the speed sensor shat itself therefore telling the power steering that the car was travelling faster than it was...therefore making the steering harder....
but why...has anyone else had this problem know how to fix it etc...
thanks in advance
Brock
https://www.sau.com.au/forums/topic/177785-no-speedo-or-power-steering/
hey buddy
had the same problem as u before.. is the hicas light on?
the reason the steering wheel is hard is because the hicas system is not detecting the speedometer..
as stated above its probably cause your speedo cable has snapped.. as that was the same with mine..
u can find one cheap of the forum for probably $50 or so.
nissan sells it for way to much..
hope it helps
yeh man...but the hicas light has been on since i picked it up in feburary...but the rest fits the problem....i need the car back now...so nissan will probaly have to do...i live in Mackay in QLD...not much chance bumping into someone with one....
hey brock,
Go to jam on monday and see if they have one kicking around, they have a container filled with gearboxes and half cuts. might be able to find one. I'll come with you on monday and talk to aaron. if worst comes to worse and you have to order one. i know a car thats off the road that has an rb20 gear box in it. with a working cable. hint hint.
Big Bro
  • 2 months later...
  • 2 months later...
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
