Taken from s2ki.com forums. (Yes, there are Honda pictures in here)
*disclaimer* I take no responsibility if you mess up!
I wanted a vented hood for three reasons;
1. To let heat (from header, engine, & radiator) escape from engine bay
2. To get cooler air into intake
3. To use the low pressure area above the hood to help extract air from under the front of the car thereby increasing velocity under the splitter and floor of the nose which should increase downforce.
Why not buy a carbon fiber vented hood? The affordable knock-off carbon hoods are heavier and less stiff than the stock aluminum hood. I believe the stock hood weighs 14 pounds. The high quality "authentic" hoods (cwest, mugen etc...) cost a bundle and still need to be painted unless you are going for the carbon look. Some if not all composite hoods require hood pins for high speed use. Oh yeah, and I'm cheap. I planned on venting both sides but ran out of time and decided I like the look of just one side. Still debating.
Here's my solution:
How to build your own:
Please use appropriate safety equipment and don't screw up.
Yes, you are about to cut holes in a perfectly good hood so be prepared.
Remove the hood and the hood liner and support it upside down on some padded saw horses.
Make templates by laying paper over each support hole you plan to cut and trace the edge (use the pencil rubbing technique). Use the templates to cut out some perforated aluminum (clean and paint the both sides of the aluminum). http://www.mcmaster.com/
Use a 3/8" spacer against the hood support edges to draw the hole shape. I left a 3/8" lip for mounting purposes.
Using a UniBit, drill a hole in each corner.
Using an air saw, cut out the shape from the under side - leave a small gap to finish off with sanding.
Use a sanding drum on a die grinder to smooth to shape. I tried using a sandpaper wheel on an angle grinder but it gets too hot and the paints starts to peel back.
Once the shape is close, flip the hood over and apply masking tape on the top side all around the new openings.
Use wet dry sandpaper to smooth the cut and feather the paint. The masking tape is there so if you slip with the sandpaper, you won't scratch up your hood.
Lay 3M double stick tape used for moldings/body work on your 3/8" lip and trim with a razor to fit just inside the cut out (find it at automotive body shops).
Use a fine paint brush and carefully paint the exposed edge with factory touch up paint.
Install perforated aluminum and your done. I used some small sheet metal clips to hold the perforated aluminum in place just in case the double stick tape failed due to engine heat but I ran a full track day without them and everything was fine.
Edited by 403_r32
https://www.sau.com.au/forums/topic/177820-diy-the-hood-hack/
that looks tough as, would look way better with bost sides done but then agian may be too busy, ohh btw if your in melb and ever need any geniune parts for your s2000 pm me, i work in spare parts at a Honda dealer, i dont mind helping out a fellow member, even if oyur not in melb and think your getting ripped pm me ill let you know.
cheers
jarrod
Well, I guess you'd really have to have steady hands if you dont want to respray the bonnet, nevertheless make a mistake! Getting a straight cut is probably the most difficult part. Sanding/feathering down the edges may be a bit tedious, but as long as you take off a fairly even amount and the edge retains an even bevel, the touch up paint would suffice.
The s2k hood was done as I said, just touched up around the edges, and as far as I'm concerned it looks pretty damn good :P As long as you have a straight cut to begin with, and have it all masked off properly there shouldnt be any problems!
Getting more air to run around the iron torpedo of a block will always help lower temperatures. Every little thing helps.
  • 4 weeks later...
  • 4 months later...
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
