Taken from s2ki.com forums.
(Yes, there are pictures of a Honda, I am sorry in advance.
:D)
*disclaimer* I take no responsibility if you mess up!
I wanted a vented hood for three reasons;
1. To let heat (from header, engine, & radiator) escape from engine bay
2. To get cooler air into intake
3. To use the low pressure area above the hood to help extract air from under the front of the car thereby increasing velocity under the splitter and floor of the nose which should increase downforce.
Why not buy a carbon fiber vented hood? The affordable knock-off carbon hoods are heavier and less stiff than the stock aluminum hood. I believe the stock hood weighs 14 pounds. The high quality "authentic" hoods (cwest, mugen etc...) cost a bundle and still need to be painted unless you are going for the carbon look. Some if not all composite hoods require hood pins for high speed use. Oh yeah, and I'm cheap. I planned on venting both sides but ran out of time and decided I like the look of just one side. Still debating.
Here's my solution:
How to build your own:
Please use appropriate safety equipment and don't screw up.
Yes, you are about to cut holes in a perfectly good hood so be prepared.
Remove the hood and the hood liner and support it upside down on some padded saw horses.
Make templates by laying paper over each support hole you wish to cut and trace the edge (use the pencil rubbing technique). Use the templates to cut out some perforated aluminum (clean and paint the both sides of the aluminum). http://www.mcmaster.com/
Use a 3/8" spacer against the hood support edges to draw the hole shape. I left a 3/8" lip for mounting purposes.
Using a UniBit, drill a hole in each corner.
Using an air saw, cut out the shape from the under side - leave a small gap to finish off with sanding.
Use a sanding drum on a die grinder to smooth to shape. I tried using a sandpaper wheel on an angle grinder but it gets too hot and the paints starts to peel back.
Once the shape is close, flip the hood over and apply masking tape on the top side all around the new openings.
Use wet dry sandpaper to smooth the cut and feather the paint. The masking tape is there so if you slip with the sandpaper, you won't scratch up your hood.
Lay 3M double stick tape used for moldings/body work on your 3/8" lip and trim with a razor to fit just inside the cut out (find it at automotive body shops).
Use a fine paint brush and carefully paint the exposed edge with factory touch up paint.
Install perforated aluminum and your done. I used some small sheet metal clips to hold the perforated aluminum in place just in case the double stick tape failed due to engine heat but I ran a full track day without them and everything was fine.
https://www.sau.com.au/forums/topic/177821-diy-the-hood-hack/
DRD-00F - Hahahahaha
holes can be cut as long as the structural integrity is not f**kd..i.e dont cut the under carrage.
Wrong. According to ADR's any hole cut in the bonnet whether it is covered in mesh or not is illegal...apparently it can spray any oil leaked by the engine on the windscreen :) people generally don't get picked on this but it is a possibility.
Wrong. According to ADR's any hole cut in the bonnet whether it is covered in mesh or not is illegal...apparently it can spray any oil leaked by the engine on the windscreen :P people generally don't get picked on this but it is a possibility.
Any hole? even for a bonnet pin?
So some of the newer model vehicles around that come with a factory option vented bonnet?
Would that not make them illegal straight from the factory?
If you get it engineered it should be fine.
  • 1 month later...
I've got the VIC ADR's linked below.
Section 10 deals with body chassis alterations, and in that it says that needs approval for modifications of any panel forward of the firewall, though it goes on to talk about cut and shuts being OK.
Later on, section 14 talks about bonnet and hood scoops, stating that it may be fitted if it is an option offered by the manufacturer to a model or series, so I guess you could argue that nismo offered vented bonnets, and they're part of nissan (though if they are covered by the term "Manufacturer" is debateable), but importantly, goes on to add "OR:" and lists the protrusion tolerances.
THEN in the QandA file, it's got frequently asked questions, and the 5th one involves non factory bonnet scoops, and the reply is that they are allowed, visibility permitting.
Because the bonnet is at an angle, it is technically a "Scoop" (i.e., the back is higher than the front, hence air is "scooped" in to the engine bay) The ADRs don't seem to mention anything about the need to cover the hole, and even allows for rear facing scoops.
It seems that you'd definately be able to argue in favour if the hole had a scoop on it, but might be up to interpretation if it's just meshed, unless Honda had a vented bonnet at some stage. Still, with a job that looks that good, you could probably claim it was like that from the shop. Still, I think you'd be OK, as the hole IS technically a scoop.
I like the look of it though. Too bad skylines aren't as artistic with their re-enforcing.
ADRs.pdf
QandA.pdf
Edited by Kozeyekan
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
