  • Replies 43
Maybe its worthwhile to make a 'Sticky' with all the good tips and advice on what to do when selling a car (you know - keep the licence etc.)
Might help some of the people out there.
Cheers
The Baron
PS : Hope you, they or we find the guy
PPS : As a tip - always ask to take a picture of the person wanting to buy your car (you know as a memento) - heck every Mobile Phone has a camera nowadays.
PPPS - Always have insurance!!!!
Thank you for all the help.
That guy called me three times before came over, but his number didn't show on my mobile. I told police about that, they said they will chase up the number.
I think he may live around Nunawading or Ringwood area, that is my feeling.
It is really bad for me. I was almost crying when my baby was running away.
I'm sorry for your lost mate. Hope you find the prick soon.
To be honest, I don't think he'll travel around the area he stole the car so everyone needs to keep an eye out for this car.
Goodluck on your search for this guy.
So sorry to hear, that is so not fair. I saw a gunmetal grey R32 GTR in Kilsyth (cnr Mt Dandenong Rd & Colchester Rd) today about 12.45pm but it had a GTR badge on the back and I didnt catch the rego number. But as someone already said, I doubt he would be driving it around after stealing it 2 days before.
We are selling an R33 at the moment so this will make us more weary of potential buyers.
Good luck with the recovery.
any witnesses..another thing surely most people would be aware that noone is going to come with the intention of buying a car at 10.30 at night no matter who they are.. you cant see much in the dark!!
hope u catch the bastard Ill keep an eye out and have a word to a few of my mates who are coppers.
I live in nunawading area and if I see any r32 gtr in that colour ill follow it and pm you when i arrive at his place. Ill look after him for ya :P
sound thrashing from the ban stick :(
any new leads on this fullo?
damn that sux bad. im from wantirna and work night shift in nunawading. my daily driven calais was stolen from my house couple of months ago, lucky as i always leave the line at home but luckily was driving the line that night (wich is rare). a couple of mates have had statesmans stolen recently aswell from the local area. lucky as the calais had a electrical error so they dumped in blackburn with a full tank of gas, so definetly local scum
ill keep my eyes and ears open for any gtr stuff going around here
hope it turns up mate
Edited by sarino
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
    • I'm not sure where you are, but United Terrey Hills has E85.
