Hey guys, I own an R33 GTS4, got it professionally converted from an N/a to Turbo last week.
It runs really well now, just a few questions about it.
I have a FMIC etc now, but before the coversion I had a 3-3.5 inch momo exhuast system with a 5 inch tip(pretty big for an n/a) along with stock dump pipe and extractors and the engine gave a real growl, sounded awsum (most ppl throught I had extractors).
Currently i still have the exhaust system, but with a stock turbo dump pipe and stock turbo extractors and it is sooo much quieter then before, only at about 5k does it start to sound remotely grunty, someone please tell me why and how I get it sounding as it was before! Thanks
would a new set of extractors do it ?
Also, it is now idling at about the same, but the engine is reving very lightly constantly, from about 760rpm ~ 810rpm roughly, is this due to the turbo?
Thanks for the help!
Adam :laughing-smiley-014:
https://www.sau.com.au/forums/topic/177850-exhaust-note/
It is unlikely that you will ever get the same exhaust note. One of the beauties of a turbo is that it utilises some of the energy in the exhaust gasses to spin the turbine. If there isn't as much energy present by the time it comes out the muffler, then it can't emit as much sound.
As for yopur idle, is it on an aftermarket ECU or factory? As it's a RB25DE -> RB25DET conversion, I doubt a factory ECU could work quite right because it was designed to operate that exact configuration of engine. But, have a look at the AAC valve - it might be slightly gummed up and sticking, so give it a clean.
PS - it's THAN, not THEN - quieter THAN before
https://www.sau.com.au/forums/topic/177850-exhaust-note/#findComment-3246518
LOL thanks for the help and the english lesson! English me speak good :thumbsup: you better watch your spelling though --> "As for yopur idle" btw it has a new s1 r33 rb25det ecu, exactly the same as mine, except for being turbo, so I did not think that was the prob for idle.
I also just wanted to know how to make it louder again, would extractors make a decent diff?
Cheers Adam.
https://www.sau.com.au/forums/topic/177850-exhaust-note/#findComment-3246873
turbo cars will never be as loud as a N/A car. 3" on a N/A would be massivly louder than on a turbo.
you have 2 options firstly (and this should be done anyway) get a highflow cat and new dump pipe. this will make it a touch louder.
secondly you could cut out the centre muffler. this will add a bit more bark to it.
https://www.sau.com.au/forums/topic/177850-exhaust-note/#findComment-3247058
Thanks for advice, so extractors/headers will not make that much difference? only high flow cat and dump? Because I was planning to do them soon enough anyway.
Thanks again, Adam.
P.S wot about the idle issue?
https://www.sau.com.au/forums/topic/177850-exhaust-note/#findComment-3247090
If you have mufflers, remove both mufflers. If you hvae them replaced with straight pipe, it should be louder and sound meaner.
Cat - same deal
Bigger dump/front pipe makes a bit of difference but nothing like changing mufflers.
Bigger turbo makes a huge difference to the exhaust note and volume. - after all, this is essentially the only difference between what you used to have and what you have now - think of it as a big butt plug in the exhaust (literally)
https://www.sau.com.au/forums/topic/177850-exhaust-note/#findComment-3247886
Thanks for the advice guys, I am running a stock ecu, from a s1 r33 turbo, so the same as mine + turbo, which I thought was good, and the engine never did this before... I thought it was the turbo setup that did it? please advise.
In terms of taking out mufflers etc.. I may consider removing the system (middle) one, as it is a b*stard over speed humps, but I don't want to make the car more illegal then what it is.. considering I am a P plater... Plus I am really happy with my current exhaust sys.. just hoping the cat etc.. could be fixed up..
No one has mentioned the extractors... are they not as good on turbos as they are on N/A's ?
And thanks for the butt plug explanation.. it all makes sense now :laugh:
I did give the car a bit of a go and at 5k it is pretty mean.. nuthing what it used to be...but anything below sounds as quiet as a little civic.. no offence, small price to pay I guess. :laugh:
Cheers, Adam :laugh:
https://www.sau.com.au/forums/topic/177850-exhaust-note/#findComment-3248034
if you want more noise you could go a screamer pipe, but on the stock turbo it can leak a bit, and will only make it louder when it comes on boost. and is rather illegal.
but do you really want extra attention from police, with the increasingly strict laws that keep bringing in?
https://www.sau.com.au/forums/topic/177850-exhaust-note/#findComment-3248321
there are no extractors on a turbo sky. it runs an exhaust manifold which the turbo bolts to and then the exhaust itself runs out of the turbo.so its like a small combinatioon of pipes (6 of them) that run to the turbo, then a dump pipe from the tubo throught 2 the front pipe and then the exhaust begins.
when you talk extractors on a turbo skyline, your talking front piep and dump pipe. they can be an all in 1 system like FLYN sell or a split dump front like just jap sell.
FLYN - http://www.skylinesaustralia.com/forums/in...howtopic=166815
JustJap - http://www.skylinesaustralia.com/forums/in...howtopic=155238
as for note, wanna make it louder, remove the rear muffler, im guessing its and oval type muffler and replace it with a cannon muffler.
https://www.sau.com.au/forums/topic/177850-exhaust-note/#findComment-3248417
i stand corrected. well then just change the front pipe and dump as well as ur rear muffler to a cannon and away u go. i had a kakimoto 3" system with cannon muffler first and at idle i was 97dB and at full noise i was 108dB, that was loud and after a while the drone got to me.
so yeh put a cannon on.
https://www.sau.com.au/forums/topic/177850-exhaust-note/#findComment-3248587
Thanks guys,
Very helpful, I decided I will change the dump pipe and cat, as well as remove the middle muffler. Think that should give me a decent increase in growl, I'm definitely not after drone, even if it means sacrificing volume. Thanks a lot for the help! :fakenopic::D
Power wise though, a 3.5 inch sys and 5 inch tip is definitely big enough for a turbo to blast out exhaust fumes? I thought it would be.
Thanks, Adam
https://www.sau.com.au/forums/topic/177850-exhaust-note/#findComment-3248628
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
