GANADOR SUPER MIRROR FOR SKYLINE R33 GTST (Full carbon model)
*95% new, used for 3 mounths only.
*High quality design matches any body kits.
*Blue mirror glass to prevent reflection from sun light.
*Body is made of carbon that offers high product quality as genuine mirror assemblies.
*Each product comes with the same wiring plug as genuine one, which allows you to plug it straight into original factory wiring. The angle of the mirror glass can be adjusted by using original factory switch. (Except for mirror folding function)
*Mirror body can be folded manually.
*Will fit the following model and build year: ECR33/ER33 (2 door), 8/93-5/98
*Item Location: Sydney
*Price: $500 (Free shipping to anywhere within Australia)
The Ganador model designation is R33 2DR or R33 4DR, so if they fit R33 GTS-T 2 Door, they will certainly fit R33 GTR :thumbsup:
thanks for the clarification, so that will fit both R33 GTST n GTR
