Ive been considering getting one of these guys for a while, but I have no idea whats decent and whats not.
Have been considering the "Navigator 3000" from Road Angel, purely because I can get it cheap (well I think so anyways) - $325 - $350.
Link - http://www.roadangel.com.au/
Is this a good unit and a good deal?? Or would you recommend something else??
Your input would be great.
Thanks,
BEC
https://www.sau.com.au/forums/topic/177875-gps-devices/
I have the Road Angel 6000... awesome to use.. maps are uploaded free whenever they are updated.. only the rd sense side of it is a subscription... thinks its $9 per month... but the first 6 months are free....
https://www.sau.com.au/forums/topic/177875-gps-devices/#findComment-3246968
TomTom.
I've used Navigator, Destinator and TomTom...
TomTom > Destinator > Navigator.
Garmin is meant to be ok as well, but go the TomTom. Keep in mind to buy updated maps cost a few hundred.... but I've heard TomTom can be acquired if you know where to look :thumbsup:
https://www.sau.com.au/forums/topic/177875-gps-devices/#findComment-3247392
Tom Tom's are very easy to use and have the best screen layout while navigating, but it missing one cruicial setting (for me anyway)
You cant tell it NOT to take dirt/ unsealed roads, coming back from NSW it wanted to take us though dirt roads in woop-woop (not happening in the hot rod we were in). It didnt even say that they were dirt roads, i recognised some of the road names close to out destination.
The Navman on the otherhand has an avoid dirt roads setting.
Another annoying item (maybe caused by me not knowing how to operate it, but if so its not very intuitive); i couldnt get it to add towns as waypoint. Say you wanted to go to Echuca via Healsville, it wanted you type in street number, name etc; things that arent necessary, i didnt know any street names to type in anyway. I just wanted it to take me via Healsville, not stop at someones place!
I havent tried this on the Navman yet so i dont know if that works for my uses.
And they are very acurate as a speedo, better thatn most car speedos. Try it and compare it to the detectors on the Geelong or Hume Hwys
https://www.sau.com.au/forums/topic/177875-gps-devices/#findComment-3248395
Shane..I owe u $20 from the drag day - pm me u details!
I have used a navman and Garmin on my yacht as a speedo, to compare the actual speed and VMG (which is another speed reading for yacht racing) againsta my actual instruments. It read clsoe if not the same and they cost like $5000 for all the bits and pieces.
In the car I use the TomTom 710 as stated before. Yeah unsealed roads anrt the best however I have never needed to use that feture. The big touch screen is really good when driving and very easy to read. My wife can use it (thats why I bought it) and she reckons its ace, press the "home button" and it directs you straight home. I just had a look in it I notice key points of intrest are CHadstone, Chapel Street, High Point and the QV CarPark. LOL sorry at home beating of..
https://www.sau.com.au/forums/topic/177875-gps-devices/#findComment-3248410
Bec/Adz - You can borrow my TomTom ONE if you'd like to see what it's like.
Very easy to use (MUCH better than the OEM system in most cars, especially Bentley) and pretty accurate.
Is here at the office now - but I can drop it into MSAC in the morning if that is useful.
https://www.sau.com.au/forums/topic/177875-gps-devices/#findComment-3249086
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
