Ive been considering getting one of these guys for a while, but I have no idea whats decent and whats not.
Have been considering the "Navigator 3000" from Road Angel, purely because I can get it cheap (well I think so anyways) - $325 - $350.
Link - http://www.roadangel.com.au/
Is this a good unit and a good deal?? Or would you recommend something else??
Your input would be great.
Thanks,
BEC
https://www.sau.com.au/forums/topic/177875-gps-devices/
I have the Road Angel 6000... awesome to use.. maps are uploaded free whenever they are updated.. only the rd sense side of it is a subscription... thinks its $9 per month... but the first 6 months are free....
https://www.sau.com.au/forums/topic/177875-gps-devices/#findComment-3246968
TomTom.
I've used Navigator, Destinator and TomTom...
TomTom > Destinator > Navigator.
Garmin is meant to be ok as well, but go the TomTom. Keep in mind to buy updated maps cost a few hundred.... but I've heard TomTom can be acquired if you know where to look :thumbsup:
https://www.sau.com.au/forums/topic/177875-gps-devices/#findComment-3247392
Tom Tom's are very easy to use and have the best screen layout while navigating, but it missing one cruicial setting (for me anyway)
You cant tell it NOT to take dirt/ unsealed roads, coming back from NSW it wanted to take us though dirt roads in woop-woop (not happening in the hot rod we were in). It didnt even say that they were dirt roads, i recognised some of the road names close to out destination.
The Navman on the otherhand has an avoid dirt roads setting.
Another annoying item (maybe caused by me not knowing how to operate it, but if so its not very intuitive); i couldnt get it to add towns as waypoint. Say you wanted to go to Echuca via Healsville, it wanted you type in street number, name etc; things that arent necessary, i didnt know any street names to type in anyway. I just wanted it to take me via Healsville, not stop at someones place!
I havent tried this on the Navman yet so i dont know if that works for my uses.
And they are very acurate as a speedo, better thatn most car speedos. Try it and compare it to the detectors on the Geelong or Hume Hwys
https://www.sau.com.au/forums/topic/177875-gps-devices/#findComment-3248395
Shane..I owe u $20 from the drag day - pm me u details!
I have used a navman and Garmin on my yacht as a speedo, to compare the actual speed and VMG (which is another speed reading for yacht racing) againsta my actual instruments. It read clsoe if not the same and they cost like $5000 for all the bits and pieces.
In the car I use the TomTom 710 as stated before. Yeah unsealed roads anrt the best however I have never needed to use that feture. The big touch screen is really good when driving and very easy to read. My wife can use it (thats why I bought it) and she reckons its ace, press the "home button" and it directs you straight home. I just had a look in it I notice key points of intrest are CHadstone, Chapel Street, High Point and the QV CarPark. LOL sorry at home beating of..
https://www.sau.com.au/forums/topic/177875-gps-devices/#findComment-3248410
Bec/Adz - You can borrow my TomTom ONE if you'd like to see what it's like.
Very easy to use (MUCH better than the OEM system in most cars, especially Bentley) and pretty accurate.
Is here at the office now - but I can drop it into MSAC in the morning if that is useful.
https://www.sau.com.au/forums/topic/177875-gps-devices/#findComment-3249086
    • Yep. And if you ever do, you'll just have to deal with it then.
    • E10 is pretty tightly regulated in percentage. Too much and engines can't adapt. Every incentive is against them to have too little ethanol though. The more ethanol the higher the octane.
    • Yeah i have R34 with factory small box and now RB25DET NEO swapoed and iam planning to upgrade to big box.  So i would be good as long as i do not change diff?
    • Based off what you’ve said here, I think I’ve figured out a good bit of what I’ve done wrong -  So on the line going from the PCV valve to carbon canister, there’s a T joint that is pretty much right next to that lower port - I hadn’t noticed that the hose in the diagram was curved to attach onto the carb, so I was putting that line for the lower port onto the PCV line / carbon canister line instead. I’m going to have a flick through the manual again tomorrow and should hopefully find a diagram that’ll show me where that T joint should be connected to. Timing also 100% needs to be sorted out as well, should be able to tackle that tomorrow as well. Definitely feel like I should be on the right track now though.
