hi
could someone please steer me in the the right direction for paper work and what ever else is required for importing a race only car, i have purchased a car in japan and need to import it , it will not be being road registered ever(circuit only car.
thanks russell
https://www.sau.com.au/forums/topic/177894-import-question/
car is being built for time attack in japan and the u.s.a
and these events are not cams sanctioned as far as i know?
cheers russell
so what do you mean?? you want to import it to australia, to build it here, to then use it back in Japan and the USA?
https://www.sau.com.au/forums/topic/177894-import-question/#findComment-3250224
even in that case, you will still need to apply for a race/rally approval through DOTARS.
I hope you like paying $$ to shipping companies!!
the link razor$harp gave you above should have all the info you need to be able to do it...
in SOME instances, you may get away with only having level 2 cams licence, but level 3 is what is normally requested.
let us know if you have any further questions.
Cheers,
Beau
edit: another consideration.... you are meant to provide with your application proof that you have competed in events here before, along with evidence of events you plan to enter over say the following 12 month period.... so if you are planning to only use it in Japan, and USA, DOTARS may not like that.
Edited by insanity
https://www.sau.com.au/forums/topic/177894-import-question/#findComment-3251530
I'm sure Russ has the competition experience required, you need to provide its plans for future competition as well. And the person who applies for approval will need a PC or NC license - but you can sell it to someone else once it is here.
Pretty sure you will need an import approval each time it is imported back again - sounds like a lot of trouble to me.
Cheaper to build 3 shells to the same specs and leave them there at 2-3k per import (RORO) and even more in a container
https://www.sau.com.au/forums/topic/177894-import-question/#findComment-3252408
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
    • I agree once misfires happen it's basically worthless, but the hope is you can see what's happening in the run up to that.
    • You should totally get a Brumby, and then come pick up the Subaru Liberty GTB I have here. EJ25 Turbo, 6 speed manual from the sti (just no dccd), and the good rear diff. Drop all that into a Brumby and go have fun!
