I'll be pickin up my new R33 GTS-t later this week and would like to do my own mini self service soon after, how’s this sound:
- Oil change (Fully synthetic? Something to accommodate freeway driving?)
- Oil filter (145a)
- Clean air filter
- Fuel injectors (metho?)
- Fuel filter (z200?)
- Coolant
- Spark plugs (NGK .08mm)
- Octane Boost :-)
- Reset ECU
- Then a Tune
Anything else?
https://www.sau.com.au/forums/topic/17792-r33-gts-t-newbie-self-servicing/
I just got my R33 on Friday, anyway upon inspecting I found that the compliance place had already done most of these things.
New Fuel Filter
New Air Filter
New Oil Filter
Changed Oil
Changed Coolant
I haven't checked the plugs as yet or the fuel injectors and I reset the ECU myself wasn't sure on that either.
You might find that a lot of it has been done for you.
I'd check/replace your gearbox oil too. Maybe even your diff oil.
I know my gearbox oil wasn't changed when the compliance was done, even though it should've been :cool:
And maybe take your AFM off and give it a clean too. There's a thread in the Maintance section about that.
Cheers
J
Sorry my post may have seemed a little misleading.
Its not a fresh import, I bought it locally.
90,000 kms on the clock.
Is gearbox oil an easy job? My servicing experience extends to Oil/Air filter changes & brake calipers.
Plugs?
Timing belt at 100,000kms I spose?
Guest RedLineGTR
prob do it now...unless it has been done before but i doubt it...but it's worth doing just just incase it is getting worn and you rather use the money now rather then it snapping and destroying nearly everything
Guest RedLineGTR
the items that he's changed...find out what he has and has not at least you will get some history..what oil has been used when wa sit last changed...make sure you check out if he can provide import papers...of some original documentation..some original details..
theres alot to do here, first dont use metho on ur injectors,
make sure u use the correct coolant, nissan coolant is good, u shouldnt mix coolants, if ur going to flush the system make sure that u do put to much coolant and not enough water, u have to get ur mixtures right
how do u plan to tune it, u need a computer to give u diagnostics on how the car is running
and u should make sure u do ur timing belt if it hasnt been done, its a big job, call around to a workshop and see how much they will charge, because u dont want things to go wrong after, its a lot of money, they will be able to tell you what needs to be done and what doesnt, ur skylines at the turning point of its life
make sure the workshop are skyline specialists
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
