Ok, so i installed them tonight
Gripes:
They have no thorough instructions
the ones that are in it, only showed how to remove the old coilpacks, and its not just a reverse installation...
Second
You cant just reinstall them into your old coilpack holders
it doesnt work...at all
you can install one bolt on each one, but when you put them on the car in the holder, its misaligned
so i didnt use it
BUt, when you install them without the holder, they are rather secure
they flop around but dont pull upwards, we shall see how it works out
It helped my idle immensly
its still high, but much more even
i also replaced plugs along with the coilpacks
TOmorrow ill bring it out for a test run before i install the wideband and SAFC2
see if it improved my boost problem at all...
anyways, more to come
https://www.sau.com.au/forums/topic/177931-splitfire-coilpacks/
the one thing I did notice .. whilst reading the instuctions on how to change the coilpacks
I think the NEO uses a slightly different configuration than the non neo motors.
Looking at the how to article.. it seems that on the non NEO motors.. the coilpacks are grouped in 3 and attached to a plate ( 2 plates for 6 coilpacks ) on the NEO the coilpacks are just held in with 2 screws per coilpack. If you got the right coilpacks for the motor . and they are not a direct fit , I would be complaining or seeking re-embursment.
there is only one set for all years WGNC34
the non neo has the bracket that are grouped in 3
ill make some kind of bracket , not a big deal
just didnt know if it was only me that had that problem or not
maybe i have an odd holder?
i dunno
doesnt work for me...ghey
i cant speak for performance
but it improved my idle alot, its alot more smoothe
im installing my HKS acutator in like 10 minutes nad ill let you know how it performs once i get my boost back.
i think my wastegate is failing
man its going to be a bit of a headf*ck to make the bracket up accurately .
why not just send em back and say they dont fit? will be a lot easier.
from what I could see of the bracket that groups the 3 coil packs together it looks like its
made out of reasonably thick ally plate. Or why not just see if you can get that plate from
a wreakers etc?
well, theo problem is i bought them from a used place, but htey wre brand new
i got em for 350 USD
which is like 250 less than everywhere else
SO...its owrth the hastle, ill just trim off the mounting parts that cover hte larger holes, and get a piece of metal and make like a T with the bolt and metal to hold htem down.
shoudl only take an hour or so
try buying your parts thru www.nengun.com (they are in Japan)
They are only $375 USD new for the right ones
I have been called worse haha..
no its just the 1st time doing it .. was just a bit of a pain .. compared to some of the other cars I have worked on . That and the breather hose being rock hard etc etc etc..
but .. got my good 1/4 drive ratchet set.. so those pesky alan keys holding the cover on dont stand a chance now.
plugs are hard to change?
Your crazy for saying that!
