Need to know what PSI base springs people are running in turbosmart 48mm wastegate.??
I have just put a 14psi spring in mine and tested with an air source it wont open the valve till it gets 20psi boost, at 14 psi the valve wont even move. I would like to run as low as 14 psi on the street , and use my EBC to run a max boost of around 20-22psi.
What springs are others with these turbosmart gates running?
And does anyone successfuly run a low psi spring and increase boost via an EBC up to 20+ PSi?
interesting - but couldn't the turbo still output 14 psi while the wastegate is actuating at 20 psi?
is selcting a spring guess work?
I suppose if the spring on wastegate is directly connected to the turbo you could get a flow bench test.
I used a 14psi spring in my 45mm Turbosmart gate (the obsolete model to the 48mm) and it opened @ 14psi perfectly everytime.
If the gate isn't opening at the desired boost level you have a couple of issues maybe.
1. Manifold isn't flowing enough air to the gate, its easier to the air to go out the turbine housing, so its doing that and not going past the gate until sufficient pressure is there
2. Kinda a silly one, but the spring could indeed be wrong.
I think there are a couple more reasons, but its 7am and i just got up :laugh:
I think there are a couple more reasons, but its 7am and i just got up :thumbsup:
Nismoid, did you use an electric boost controller to boost up over your 14psi base? How much boost?
I havnt tried it on the car yet, i just used compressed air to test when it opens, and it didnt open till it seen 20psi.
I have the single big red spring which is meant to be 14psi.
Anyone else confirm??
Perfectly. :(
No gate creep at all.
I did have some gate creep issues under high load when using the 7psi spring, and bleeding upto 17psi.
But going to a 14psi spring and going up from there worked fine
i use a 45mm pro gate with the 14 psi spring and it holds perfictly.. i have also used the $22 boost controller to bump it up to 17 psi and it held perfictly... but havnt tried to raise it anymore...
have you had previous success with the setup you are using or is this the first time it has been put together with a new setup??
Did you think of exhaust manifold pressure helping to blow the gate open?
We have a winner....
My 17psi spring wasnt opening till about 25ish psi but I added slight pressure with my thumb while testing it and it open fine on 17psi. Once fitted in the car was spot on 17psi
Edited by WHITER33GTS-T
Odd, iv seen gates bench tested that open at XYZ boost, then when fitted. open at XYZ
Almost the same as above. I have a 14psi spring in my tial 46mm gate. I hook it up to the compressor and it only opens at 28psi (fully opens that is). However, applying slight pressure to the gate piston with my thumb at about 20 psi, it opens up fine and probaly would at 14 psi, cant remember if I tired or not. So its really quite normal (the gate not opening until a higher than expected pressure) if you do not apply pressure the gate also at the piston thereby mimicking exhaust back pressure, the latter is certainly going apply more pressure than your thumb.
BF
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
