Hey Guys,
Around 3 months ago I trusted my car to a workshop in Maylands to paint and fit an aftermarket front bumper to my 33. Initially I was happy with the end result, however about a week ago while washing my car I noticed that the paint had chipped away all over the place, seriously must be the shittest paint job ever. Anyway, I had a look through all my receipts and can't find the one concerning this particular job. Never had this happen to me before. I'm pretty sure if I rock up there and tell them they did a shit job they'll just laugh at me.
What would you do?
https://www.sau.com.au/forums/topic/177959-shtty-paint-job/
If it was only 3 months ago, surely they will remember the car...
I'm sure if you go in there and bat your eyelids at them they will work something out for you. :laugh:
Failing that just never wash the front of your car again. :laugh:
https://www.sau.com.au/forums/topic/177959-shtty-paint-job/#findComment-3248085
this happened to me to down here in bunno. got told to f**k off by the guy. he didnt prep it well enough an the paint chipped off and small surface rust spots have shown up. now im gona do it proper myself
https://www.sau.com.au/forums/topic/177959-shtty-paint-job/#findComment-3250118
i used to do work at a bodyworks, post pics of the areas... is it just the clear comming of? being a bodyworks they should of used 2pac paint but iv heard that some will use acrylic, which is ok, but it could of had a reaction with undercoat, iv also heard of some places spraying directly over the gel coat which over time the paintwill come away from the bumper
it would be wise to go back and give them a piece of mind, my boss got a job done on his HZ GTS and it ended up going back 3 times!
https://www.sau.com.au/forums/topic/177959-shtty-paint-job/#findComment-3252051
    • Sell it and buy something newer? 😛
    • Better then PooPooG... or is it PeePeeG?
    • The steering wheel on my 97 s3 gtr is a little bit worn out, so im on the hunt for something mint. I notice that this type of steering wheel is on several other nissan's of the era.  Does anyone know if their all identical, or are there slight differences? I feel like gtr tax applies to anyone selling one, but if it comes from any other car the price is much less, even though its the same design.  Chat gpt says the material for the gtr is slightly different and it says gtr on the wheel, but every pic ive seen it just says nissan.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
