Hi guys,
I recently spun a big end bearing in my RB25 at a track day... this is the second time I have had to rebuild so it was a relatively fresh engine (25,000km)... I have already been over most of this but wanted to throw it open to the whole forum, see thread here for more info http://www.skylinesaustralia.com/forums/in...howtopic=173225
I don't know whether the problem is oil starvation, oil contamination or misassembly from the previous build... so I'm going to try and cover all 3 with this build... I don't have any pics of the bearings but #2 took most of the punishment ... my mechanic and myself will be doing everything excluding machining so I need all the info I can get
engine will be used on the street as well as frequently at circuits and motorkhanas... will only be pushing 200rwkw for the time being but when my bank balance recovers we will be going for no more than 300rwkw... reliability is the number 1 thing I want to achive, I want to be able to thrash the living hell out of it and not have to take the engine out again any time soon (ever if possible! pain in the butt to take an RB out!)
parts list:
New RB26 crank
ACL race bearings (no more aluminium!)
Eagle rods with ARP bolts
Arias pistons and rings (already in there from last build)
N1 oil pump
N1 water pump
ACL gaskets
Nismo engine mounts (current ones are shagged)
Oil cooler (yes I should have already had one!)
oil control:
block off front oil feed to head, 1.25mm restrictor in other oil feed, leave VCT feed alone
external oil drain from back of head to sump
clean up of oil galleries for improved flow
That's about it but I have a couple of questions:
is the JUN oil pump worth $450 more than the N1? I am happy to pay the extra as long as its not just for the brand name...
If I were to go a stroker crank would the extra .3 of a litre be worth an extra $2000? been thinking of RB30 but that would be a similar additional cost as I would have to buy new pistons
in the other thread there was some argument about a baffled sump, do I need one?
Cheers,
Nick
I am sure you have already thought of it but RB30DET :) then no need for rb26 crank
the cost of the build would be nearly the same. you would loose VCT but the extra capacity is a big bonus
Hi guys,
parts list:
New RB26 crank
N1 oil pump
N1 water pump
ACL gaskets
oil control:
Cheers,
Nick
I think a baffled sump would help when doing track work. Also slightly over filling the sump helps too.
RB30 you don't need new pistons for 200-300rwkW if you get a good rb30, you just need the pistons ceramic coated.
Was there much oil in the catch can when the motor let go? I think the rb25 pump will be fine and if you follow all SK's oil control modifications you should have reliable motor.
i like the rb26 crank upgrade as ive done the same hehe but this was 3 years ago and the rb30/twin cam thing wasnt as well advertised then as it is now so in away im spewin i didnt go that way, but at same time am happy with results so far with 2.6 crank... i would prob recommend going for rb30/twincam setup. roughly same costs and benifits from wat ive heard are well worth it....
You dont need $$$ rods.
GTR rods for $150 are more than upto the task with decent bolts.
They will hold another 100rwkw over what you will ever want.
Personally, i'd have Racepace built it, and thus... contact em for their thoughts :pirate:
thanks for the input guys:)
GTSt-Vspec - I will look into the Nismo bearings, just don't want to go with aluminium again as it isn't as resiliant as the lead/copper
RB30 will definately be more expensive than this build, just due to the little fiddly extras (like plenum and rerouting the cooler pipes etc), I don't really want to go back to cast pistons and I don't want to use high km second hand parts if I can avoid it... GTR rods would be okay I guess and would save me enough to get a baffled sump or the JUN/HKS oil pump... I will be blueprinting/balancing everything I can lay my hands on anyway
yep Ben would do a better job than me but where is the fun in that;)
no idea what the difference is between the OEM - Nismo mounts are... but Nismo FTW;)
Thanks Adriano I wasn't sure if I could use the 26 crank and rods with the Arias pistons already in there... but when I bought the pistons they were 26 spec anyway as arias don't make 25 spec???
very true ash, it gets a little less fun every time hehe
Definatly go the JUN/HKS or Tomei pump depending on your available dollars. Ive heard rumour that the new N1 pumps are failing due to problems with the quality of the metal in the pump rotor. With the gtr crank make sure it has the oil pump drive extension fitted if its an R32 GTR crank. Especially considering how your circuit race it. Last of all if you can afford to, put in a set of H-beams. Cheap insurance.
Same oil pump mods should be done if your going down the RB30DET path and still will race the car as well.
Sump baffel definatly or oil surging can still cause bearing failure like you already have. The other possability is a sump extension to add a few more litres of oil to the sump. Extra oil in the oil lines from the cooler and remote filter doesnt help if the pickup is sucking air.
Have fun with it!
    • Atmospheric vent requires something that doesn't use a MAF for load. You would need a standalone ECU for that.
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
