bought a skyline recently( off my old man )
its pretty much stock with only a catback ex, pod, microtech ECU. being tax time i am looking at changing that a bit.
currently got a T03 turbo from a VL in the shed and was think of getting it highflowed and putting on the liner also with the addition of a FMIC, front pipe, highflow cat and fuel pump.
my question is, many people here ventured out there and used one on there skyline? how do they perform?
cheers mick
https://www.sau.com.au/forums/topic/178005-garret-t34-highflows/
DO NOT put a VL turbo onto your skyline. For a few reasons.
1: they are bush bearing and a old design
2: you need to mod the oil lines
3: you need to make a custom dump pipe because the wastegate flap is on the dump pipe and its a major pain in the ass
4: it will be laggier and will not make hardly anymore power then a stock turbo
The reason why i know this ? is because i have put one on my r33 before. Biggest piece of shit turbo you can get for a r33. Sure if your putting one on a old datsun or something but seriously if you have a skyline by the time you have finished the job you have spend more then the cost of a new GCG turbo and will have less power.
You have been warned =)
Edited by Guilt-Toy
t3/t4 turbos are not a bad thing. Just like rb25 highflow turbos, if you get a good one if you get a good one, they're awesome. If you get a shit one, they're shit.
Send GT-Shortie a pm about the r3/t4 turbos. He had one on his car until he had a stronger motor built - wanted more power etc.
His t3/t4 is for sale. Had better response than the rb25 highflow and made great power. It's in almost brand new condition too.
Edit: Forgot to mention, if you get a good one (like his), it is striaght bolt on - comes with evertyhing you need.
Edited by MANWHORE
What engine is this going on, RB30 or twin cam RB20/25 engine?
If its an RB30 R31 as your avatar depics, then the t3/t4 is the logical choice as its straight bolton.
If its got a RB20/25 conversion then get a RB20/25 turbo high flowed as it will go straight on and have the advantage of ball bearing response if you build it back to that spec.
Bluey1 the cop VL, ran 10's on a t3/t4 highflow, was power ported but retained stock turbine and compressor housings, it was done by ATS. (Was stripped and ran race fuel of course)
At the end of the day, highflows are kind of old school and the Garrett GT series turbos really do offer good value and performance for their money. So you need to think what the long term goal is, to save spending twice.
as stated in my first post, it is going on my new R33, basically the only reason i was looking at highflowing the the t3 is because i have one, sitting in the shed doin sweet FA and read in the RB25 mod thread about a bloke doin 250 odd kw on pretty low boost with one. At the end of the day my goal is too see between 250-270rwkw safely with the auto.
By what i have read, these figures arent all that hard to acheive with a 25 and also with the auto, with a few supportive peices of hardware. Generally as i am only a young bloke i am not made of millions and the cheapest way is the best way
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
    • And....if that could be true for all R34 GTTs, then it might be good. But in reality it is not really any better than my standard instruction to "go out and have a look at it yourself, and wave a tape measure around" etc etc, because as soon as you have any adjustable arms, or coilovers with smaller diameter springs, or tyres that have any bulge that goes out further than the rim, etc etc, then the simple version of the information is still potentially misleading. Plus, nothing in this is static. Everything is moving. At the rear the wheels swing inward at the top as they go up, so the clearances on the inside change as the suspension is compressed. At the front it's even worse. And then you have the difference in absolute wheel position in the arch can move around more, or less, depending on how compliant the bushes are. If, like me, you have sphericals on the front caster rods (and on the FUCAs also, but these are probably less dominant when it comes to wheel position), then your wheel will swing forward/backward under loads, as well as up/down, as well as steering angle. You end up having the simple numbers with 17 caveats/footnotes for each.
