Clean white R32 GTR – late 1993 model, good condition, interior perfect etc.
83'xxxKM's - engine built @ 79'xxx
Location: Toowoomba - QLD(just over an hour from Brisbane)
Email: [email protected]
Phone: 0424529457
Bit of a list I put together…
Handling:
Ohlins coilovers
Whiteline rear sway bar
Hicas lockbar
Nolethane bushes front & rear
Whiteline front swaybar
Aftermarket castor rods
Strut bar
Slotted DBA rotors front & rear.
Braided front & rear brake lines
Japanese rims with Federal 595SS rubber
Engine:
Oil Control:
• Tomei restrictor
• External oil return from rear of cylinder head to sump
• Heads match ported
• Oil gallieries 20% larger
• Baffle in cam covers
• Tomei sump baffle
Block machined & chemically cleaned
Shotpeaned rods
Tomei brake cylinder stopper
Titanium split dump pipes
Trust exhaust
R33 GTR crank
N1 oil pump
ACL bearings
Tomei oversized pistons
Tomei gaskets
Tomei Pon cams & gears
Tomei timing belt
New harmonic ballancer
N1 water pump
All new belts
HKS2530 turbo’s
HKS IC pipeing kit
100mm thick Trust front mount intercooler
Additional PWR external oil cooler + GREX oil filter relocation kit. Earls braided lines & fittings.
Modified 75mm PWR alloy radiator
Custom recycling catch-can
Bosh 044 fuel pump
600cc Injectors
Aftermarket clutch
Blitz Sus pod air filters.
Clear cam cover
Bonnet pins
Interior & electronics:
Aftermarket mafless ECU
Turbotimer
HKS Electronic boost controller
Omori gauges(Oil temp & pressure, water temp)
HKS boost gauge
Tacho with shiftlight.
Penlight for low oil press warning
Short shifter
Driver & passenger genuine Recaro SR3 reclinable bucket seats including genuine recaro rails.
RPM race gear driver & passenger harness’s
Other stuff:
Genuine Momo steering wheel
Razo shift knob
Nismo fuel cap
Razo pedals
New Sony headunit
No expense spared, oil(Motul 300v Competition) & filters changed every 3000KM’s. Motul RBF600 brake fluid.
Car will not disappoint, pleasure to drive have ensured all mods done right so no problems with defects etc.
450HP at all four
$29'900 Negotiable
https://www.sau.com.au/forums/topic/178011-built-r32-gt-r/
  • 3 weeks later...
