This vehicle had been stolen at Nunawading Railway Station Victoria around 10:30PM on 23 July 07. If anyone have seen it, please contact the police or me, any useful information will be rewards.
If you can help me to find the car, I will sell the car to you for $10000.
So please tell, email all your friends or relatives in Australia, the car may sent inter-state already.
SAM
0403465731
Car detail:
1990 NISSAN SKYLINE HR32 GT-R
Reg Plate UNB100
VIN: 6U9000BNR32009006
Engine Number: RB26 031458A
Build Month: 06/1990
Kilometres 61,000
Body 2 door 4 seat COUPE
Colour Gunmetal Grey
Interior Colour Grey and Light Grey
Transmission 5 speed Manual
Reg Expiry DEC-2007
more details:
The car has a small dent on the top of each side's front guard.
When the light is on, only the inside pair of round tail light will be on all the time, all four round tail will be on whne you press the brake.
The Nissan and GTR badge had been taken off and the boot had been repainted, so you will see nothing on the boot.
A top mount brake light had been fitted on the top of rear windscreen for compliance.
Carsales ads link
RAWS details
https://www.sau.com.au/forums/topic/178065-stolen-gtr/
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
