I didnt think you could use mild steel for cooler piping as it would rust. When you say rust proof it do you mean rustproofing both the inside and out? If so, how do you rust proof the inside??
powder coating the insides is possible, just difficult to get 100% coverage
https://www.sau.com.au/forums/topic/178073-cheap-piping/#findComment-3254164
Was going to make a new thread but Im curious if anyone would want to fabricate me some cooler piping, I was going to buy a Blitz LM intercooler for my r34 as it directs piping back under the cooler and into stock pipes but my other option is a titeass front mount and pipes.
Can anyone help? Sorry bout the highjack but why waste space..
Oh ill pay too :D in sydney
https://www.sau.com.au/forums/topic/178073-cheap-piping/#findComment-3255363
  • 1 month later...
in my opinion stanless is the go easy to work with look great can be shiny can be mashined look or you can paint it and every place has it mandrel is good cause you can buy it at any decent fabricator,zaughst joint
i have doen all of mine in stainless always and when you are putting 20 psi thru it you can clam it down as hard as you want and the hoses wont blow off it would be the same price as ali
https://www.sau.com.au/forums/topic/178073-cheap-piping/#findComment-3325707
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
