sorry to hijack this thread, but on an aftermarket gauge on idle for rb25 how much vacuum should you see?
and is there anyway you can tell that you have a vacuum leak or a leak of some sort!
hopefully someone can help!
cheers in advance!
Wasn't going to get involved in this one but here goes .
For a start please delete all notions of "negative pressure" and pistons or engines "sucking" . Firstly negative pressure doesn't exist - its as simple as that . You have a total vacuum or zero and everything above that is positive pressure . We have been brought up with this brain dead notion that atmospheric pressure at sea level is zero and anything less - is negative ?
The technical terms are PSI"A" meaning referenced from absolute zero and PSI'G" meaning PSI Gauge pressure referenced from sea level atmospheric ie ~ 14.7 PSI/1000 millibars .
Your Skylines manifold gauge is whats called a compound guage because it measures either side of 1 BAR or 1 barometric which is 1 atmosphere at sea level .
If you look at turbocharger compressor maps you'll generally see a reference on the left hand side of the map and the units used are pressure ratio (PR) . This is because 1 PR = 1 atmosphere = 1 BAR = 14.7 lbs/square inch = 1000 milibars .
The map really only tells us anything useful once the turbo can generate pressure greater than atmospheric and thats why the scale starts at 1 PR .
Start two . Engines can't "suck" . What they can do is generate an area of lower pressure than atmospheric so the atmospheric pressure being higher forces its way into the cylinders - minus any restrictions that hinder its progress . This is the reason why its so important to have low restriction filters and everything else between the atmosphere and the cylinders themselves .
NA competition engines can have high volumetric efficiency built into them but it doesn't fit in with the noise/emissions/power characteristics in road car engines . Supercharged engines (forced induction) can easily get good cylinder filling because they have greater than atmospheric pressure at times in their inlet manifolds so the restrictions down stream of the compressor are less of a problem innitially anyway .
The whole reason to supercharge a piston engine is to get higher torque that the same sized NA engine can develop . These days engines are far more complex than they used to be so turbocharging is not as simple as it once was .
In my mind I think a better measure of forced induced vs NA performance is torque and all engines are different on that score . For example a 4.5L 4 cam Jap V8 may make better overall power than a Holden 5L iron nob but both will be way ahead of your RB25T at lowish revs .
Turbo or mechanical supercharging is not a free ride and they create as many problems as they solve in high performance tune . One of the biggies is that once you get more air and fuel in to make higher cylinder pressures you get a higher volume of exhaust gas to have to deal with - bigger engine exhause flow . In some ways this is the most important aspect to deal with
because even though the engine only operates in a supercharged state some of the time its exhaust tract has to cope with high mass flow all of the time . Its a big ask to drive a healthy sized turbine that won't create unacceptable restrictions and have the engine responsive as well .
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
