Hey
I've been searching for a while now and keep coming up with the same old descriptions and specifications
I just want to know what the main differences are between SAFC1 and SAFC2.
I presume the SAFC2 has more load points and obviously looks different so the SAFC1.
Can someone post up some specifications..
Would you say the SAFC1 is now outdated and best to go SAFC2? I am having trouble finding one at a reasonable price and have bought an SAFC1 now.. but not sure if i should use it or what.
I mean, if there is a major different between V1 and V2, then yeah, but if its the same shit then I will just use SAFC1.
I am also referring to the blue screen SAFC, not the ancient dial version :pirate:
Don't know how much of that makes sense, I'm pretty tired, hungry and out of it, lonnnng day today..
Thanks in advance,
Abu
Edited by abu
https://www.sau.com.au/forums/topic/178097-safc1-vs-safc-ii/
Basically the SAFCII has a knock sensor and the extra load points and a scroll wheel instead of 4 buttons. In the end they will get the same result - dunno how much the few extra correction points make to real world performance as the safc creates a smooth curve between points. The monitor mode may be different as well but essentially the same. I just bought the number II cos i wanted one brand new with manual etc - and for the knock but i dunno how accurate the knock readings are anyways.
safc1 has 8 correction points that can be adjusted in 500rpm increments. thats about all it does.
safc2 has 12 correction points that can be adjusted in 200 rpm increments and has the ability to run 2 maps (usually 1 tuned, and the other standard) and it has the ability to minitor knock.
safc NEO has 16 correction points, VTEC controller built in (i.e. VAFC built in) as well as all the features the safc2 has but has a colour display that kind've turns me on.
That is the answer I was looking for.
So 2 maps, 1 standard. So pretty much you can switch the SAFC2 off and you will be running off standard ECU.
SAFC NEO with the 16 points is another advantage, as well as the SAFC2 features..
Although I am just looking for something basic to do the job, so SAFC2 would be good, because I would like to have 2 maps, standard boost and high boost would work?
Time to weigh up prices and see whats available!
Thanks for your help man, much appreciated.
Abu
Edited by abu
Neo also has no knock sensor.
the knock sensor on my safc2 was a life saver. i turned timing over a bit too much, i saw it hit 99 then started to hear a little pinging AFTER.
i set it to flash if it went over 40 knock, otherwise i would've have known and blown my motor to bits..... again.
Hahaha lucky hey.
Hard to find a SAFC II for sale, been looking pretty hard..
What mods you got and how much power you making with the SAFC II?
Thanks,
Abu
Edited by abu
OK so I got me an SAFCII but the whole thing is in Japanese, as it would be lol
Anyone have a English manual for one of these by any chance?
http://www.skylinesaustralia.com/forums/in...showtopic=85232
Thats the DIY I found on doing the installation so I will be following that.
Also just want to know how to set it up to run stock fuel map until I up the boost and can take it to a dyno to get it tuned?
Thanks,
Abu
in one of the menus there will be an option to "initialise". that will delete all data that has been input into the unit.
i recommend doing that and starting from scratch.
OR you can scroll through and find "file select" or something like that. this will allow you to choose between the 2 data files by going to the column which says "ON OFF" and pushing the joystick up or down to select.
this is all off the top of my head so follow it only as a general guide.
You can have it all prepared/installed as in have it clipped, femal/male plugs attatched and then plugged back into the original position. All powered up and running too.
Then when ready to tune, just unplug that 1 wire and re-route the signal to go thru the SAFC unit.
If you use the plugs supplied, no further soldering will be required to make the signal go thru the unit or back to the original position.
It'll make sense when you are doing it, I'm crap at decribing it at 5am.
Thanks for that man. Will have a better look now that I am half awake and sort of know whats going on.
Abu
Are you saying plug the male and female plugs that go into the AFM into them selves?
Thanks,
Abu
Once you install the safc it will just run the stock fuel map because no correction has been applied to the load points. You can have it fully installed and driving around and all it will do is display values such as throttle, air flow, knock etc. If you install a brand new safc it is fine to drive around with it untill it gets tuned because it hasn't changed anything. Otherwise if it is used just check that in the 'settings' onder 'high throttle' and 'low throttle' everything is on zero correction and you will be sweet to drive. Don't have to worry about disconnecting it etc. :)
Thanks,
Abu
Go to www.apexi.com.
Select the picture on the left (America)
Select 'Support' at the top right of screen
Select 'Installation Manuals'
Select 'SAFC II Instuctional Manual (401-A911)'
That might be what you're after
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
