Once you install the safc it will just run the stock fuel map because no correction has been applied to the load points. You can have it fully installed and driving around and all it will do is display values such as throttle, air flow, knock etc. If you install a brand new safc it is fine to drive around with it untill it gets tuned because it hasn't changed anything. Otherwise if it is used just check that in the 'settings' onder 'high throttle' and 'low throttle' everything is on zero correction and you will be sweet to drive. Don't have to worry about disconnecting it etc. :)
Ah awesome mate, thanks heaps.
I hooked it up to a power convertor and have been fiddling around with the settings to get an idea of how to set it up! Very interesting, and has a lot of features. Slowly getting the hang of it.
I will reset it, and check the settings under high throttle and low throttle before I start the car up.
Will have a go at installing it sometimes early next week when the car arrives.
Thanks for your help.
Abu
Go to www.apexi.com.
Select the picture on the left (America)
Select 'Support' at the top right of screen
Select 'Installation Manuals'
Select 'SAFC II Instuctional Manual (401-A911)'
That might be what you're after
Thanks for that man.
FOG35 was nice enough to PM me the 2 x PDF files for installtion and configuration.
Thanks,
Abu
Are you saying plug the male and female plugs that go into the AFM into them selves?
Thanks,
Abu
When you check the instructions, you'll notice all the wires are only tapped into to get a reading from, like throttle postion, knock etc.
Although, the one wire that has the Air/Fuel signal is the one getting altered so it's not just tapped into, you CUT it in an appropriate spot and route the signal thru the SAFC to fool the Nissan ECU.
So get everything done, cut it and attatch the male female plugs supplied which is then supposed to be plugged, 1 end into the SAFC, and the other end out of the SAFC.
But if you're not using it yet, just plug the female/male plugs you made up back into the original position, so that the wire and it's signal is unaltered (except for 2 plugs now in the middle) and not going thru the SAFC at all.
Everything else will be fine and showing the other readings.
The throttle pos sensor is the best :P
BUT, as someone else said, there's somewhere in the menu to turn the maps off (which i didn't know) so just do that if you want.
Have fun!
Birnie
Have fun!
Birnie
Ah I see now sort of! Its making more sense. I will have to read over that again and follow the steps in the wiring diagram to ensure that I get it hooked up correctly.
Pretty straight forward though, wont take long at all.
So if the SAFC II is reset or is brand new and never used or altered, I can plug it in and it will run my standard fuel map unaltered, as long as the 'settings' under 'high throttle' and 'low throttle' is on zero correction?
Just confirming before I break some shit! lol
Thanks guys, been a really big help.
Abu
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
    • It's more like on average the things I see a lot of things going wrong. Yes, usually the people who reach out are the ones who are having problems but on average it feels like mechanics and tuners here aren't really competent. I swing between thinking my standards are just way too high and wondering whether people really are just this dumb. I just had the strangest 10+ reply argument on a Facebook group over someone insisting that the factory R34 GTT boost control solenoid reduces boost pressure to 5 psi when it's on and raises boost pressure to 7 psi when it's off despite showing the exact plumbing in the factory service manual and the solenoid behavior detailed in the FSM.
    • I steam cleaned my near new set of volk gtc wheels 14 years ago and farrkkked them lol. The clear coat cracked like spider webbing in several areas. Lesson learnt don't do that. 😭
    • If you don't touch the CAS, then you're fine.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
