Here are description and a few pics of my 1991 A31 Cefiro in Thailand....
I bought it over 1 year ago with a 1JZ fitted, and rear coilovers. It was actually a bit of a mess mechanically at the time, but looked nice on the outside. The car is affectionately known as "moneypit" based on the amount of money that it has swallowed to get it almost to the state that I want to...
- Toyota 1JZ-GTE [pretty much standard tune]
- Toyota manual gearbox [totally indestructable!!!]
- Huge no-name FMIC
- Aluminium radiator with 2 twin-speed cooling fans
- Modified air intake pipe with K&N filter
- 3" straight through exhaust system
- Bailey twin piston dump/blowoff valve [about to be replaced for a Blitz]
- R33 GTS brakes
- Top Secret coilovers [front and rear]
- Front and rear strut/sway bars
- Adjustable rear camber & toe arms
- Alloy subframe bushes
- 17x8" wheels with 41 offset [front 225/45/17, rear 265/40/17]
- TBO [aka 'wonder'?] front, rear & sideskirts
- Sony GT550 mp3 head-unit
- Sony 6.5" 3-way speakers
- Sony 10-disc multichanger
- Sony 500w amplifier
- Sony 12" twin coil subwoofer
- Turbo-timer
- Guages
- R32 handbrake and console
- Modified auto-center console around the gearstick and stereo [texture removed and colour-coded black]
- Black carpets, black seats with grey [home-made] floormats....
- Sunroof
Here are some pics:
I'm sure there's other stuff that I've forgotten, but I've done loads to the car since I bought it, and my girlfriend thinks that I spend more time, effort, and money on the car than I spend on her..... maybe she's right? :rolleyes:
Edited by AlcoholicA
https://www.sau.com.au/forums/topic/178146-my-1jzgte-a31-cefiro/
  • 3 weeks later...
Thanks for the comments guys....
Ooooh, Top Secret coilovers, they'd be nice
They ARE nice... they were pretty expensive when I bought them, but I have to say it was money well spent!
How pricey was the conversion?
The already car had a 1JZ when I bought it over a year ago, but developed engine knock.... rather than rebuild that engine, I just replaced the whole engine - about $1,000 aus, and about $600 aus for service, which included completely rewiring the engine-bay.
nice car, note the 200klm/h speedo. did it have leather trim from the factory?
it's not actually real leather... so not standard from the factory [although there are plenty over here in Thailand that are] it's that fake-leather stuff but reasonably well done.... I'd love to get a set of recaros trimmed up the same
  • 4 weeks later...
looks like r32 center consol??? fits alright?
Well spotted, although I think I listed it in the mods - yeah it fits ok... the guys who originally fitted it didn't do a great job but I refitted it to make it better, although I'm not entirely happy with the result because of overlapping endges on either side around the gearstick console, but since it's better than it was I'm not too bothered. WIth a bit of patience, you'd be able to make a pretty good fit.
  • 1 month later...
  • 1 month later...
  • 4 months later...
  • 6 months later...
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
