Here are description and a few pics of my 1991 A31 Cefiro in Thailand....
I bought it over 1 year ago with a 1JZ fitted, and rear coilovers. It was actually a bit of a mess mechanically at the time, but looked nice on the outside. The car is affectionately known as "moneypit" based on the amount of money that it has swallowed to get it almost to the state that I want to...
- Toyota 1JZ-GTE [pretty much standard tune]
- Toyota manual gearbox [totally indestructable!!!]
- Huge no-name FMIC
- Aluminium radiator with 2 twin-speed cooling fans
- Modified air intake pipe with K&N filter
- 3" straight through exhaust system
- Bailey twin piston dump/blowoff valve [about to be replaced for a Blitz]
- R33 GTS brakes
- Top Secret coilovers [front and rear]
- Front and rear strut/sway bars
- Adjustable rear camber & toe arms
- Alloy subframe bushes
- 17x8" wheels with 41 offset [front 225/45/17, rear 265/40/17]
- TBO [aka 'wonder'?] front, rear & sideskirts
- Sony GT550 mp3 head-unit
- Sony 6.5" 3-way speakers
- Sony 10-disc multichanger
- Sony 500w amplifier
- Sony 12" twin coil subwoofer
- Turbo-timer
- Guages
- R32 handbrake and console
- Modified auto-center console around the gearstick and stereo [texture removed and colour-coded black]
- Black carpets, black seats with grey [home-made] floormats....
- Sunroof
Here are some pics:
I'm sure there's other stuff that I've forgotten, but I've done loads to the car since I bought it, and my girlfriend thinks that I spend more time, effort, and money on the car than I spend on her..... maybe she's right? :rolleyes:
Edited by AlcoholicA
https://www.sau.com.au/forums/topic/178146-my-1jzgte-a31-cefiro/
  • 3 weeks later...
Thanks for the comments guys....
Ooooh, Top Secret coilovers, they'd be nice
They ARE nice... they were pretty expensive when I bought them, but I have to say it was money well spent!
How pricey was the conversion?
The already car had a 1JZ when I bought it over a year ago, but developed engine knock.... rather than rebuild that engine, I just replaced the whole engine - about $1,000 aus, and about $600 aus for service, which included completely rewiring the engine-bay.
nice car, note the 200klm/h speedo. did it have leather trim from the factory?
it's not actually real leather... so not standard from the factory [although there are plenty over here in Thailand that are] it's that fake-leather stuff but reasonably well done.... I'd love to get a set of recaros trimmed up the same
  • 4 weeks later...
looks like r32 center consol??? fits alright?
Well spotted, although I think I listed it in the mods - yeah it fits ok... the guys who originally fitted it didn't do a great job but I refitted it to make it better, although I'm not entirely happy with the result because of overlapping endges on either side around the gearstick console, but since it's better than it was I'm not too bothered. WIth a bit of patience, you'd be able to make a pretty good fit.
  • 1 month later...
  • 1 month later...
  • 4 months later...
  • 6 months later...
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
