Hey guys, in the middle of a conversion, RB25det upgrade from my RB20det. The RB25det harmonic balancer has 2 decent cracks around the front rim, which im sure will tear what ever belt i put on in half. So looking at my RB20det balancer (with no cracks)... they are slightly different but the over all 7 timing marks are visually the same.... just checking if these are ok to swap?
RB20det balancer
RB25det balancer
timing marks (visually identicle on both)
thanks!
https://www.sau.com.au/forums/topic/178167-harmonic-balancer-rb20det-rb25det/
only diference is the number of ribs for the power steering belt
rb20 and rb26 from r32's run a larger belt for the power steering and hicas pump (pumps from front and back)
rb25 and rb26 from 33/34 run one less rib on the belt becuase the hicas is elcetric so less stress/load on the power steering pump
so no you cant run an rb25 ballance unless you run an rb25 power steering pump and remove the hicas (this is what i have done)
ok... well i know that the timing belts are the same for the rb20det and the rb25det and the timing marks are the same on the balancers.... im guessing its ok to just do a direct balancer swap (use rb20det harmonic balancer on rb25det).
I will be using the R32 power steering pump and air compressor still because i have left them attatched to the engine bay and ready to be bolted to the rb25det when its dropped in... meaning i wouldnt have to change any belts either (Rb20det power steering pump and rb20det balancer).
Tomorrow i will measure the balancer sizes and post up results, just for reference if anyone else needs to do the same.
Cheers
Edited by zertek
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
