Ok so the 32 is pretty close to being done but there are a few things that i either need a hand with or someone in the know to finish off. As the car is still not moving i would need said person to come to the house to do the work.
Its about half a day away (or less) from being ready to fire up again :stupid:
The sooner i get it running the sooner i can get it registered and tuned.
Let me know if you know anyone, ESPECIALLY IF FREE THE NEXT COUPLE OF DAYS!!!
Cheers GMB
https://www.sau.com.au/forums/topic/178221-mobile-mechanic/
If anyone is free Sunday and feels like giving me a hand there is cold beer in the fridge for payment >_<
Car has to be running by next weekend so it can be driven to be finished off before tuning >_<
Cheers GMB
https://www.sau.com.au/forums/topic/178221-mobile-mechanic/#findComment-3263550
So what is left to do GMB? Should have been up and running ages ago dude! What problem have you run into :worship:
Not far from running but a bit to do till its finished.
Mainly electrical that have left me scratching my head cobber but im getting there ;)
https://www.sau.com.au/forums/topic/178221-mobile-mechanic/#findComment-3265908
what is the drama benny? are you not going from 20 to 20? what has changed?
Mainly electrical old boy but snagged a few little problems along the way as well :worship:
Few things changed but all revealed in good time ;)
https://www.sau.com.au/forums/topic/178221-mobile-mechanic/#findComment-3281862
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
