hi all, I have a series 2 r33 for sale. it's a manual, completely stock
and is fully maintained (oil and filter changes every 5000k's) I have a number of reciets showing all the maintenance I have performed on the car. It is my pride and joy and is kept in a garage under a car cover for most of the week except on weekends (I have a company car that I use to work). The car is very healthy as it doesn't use a mm of oil and the oil is still clear when I change it. I have taken it to Willowbank once to see what it would run and I have a time card to prove it ran a 14.4 at 19 deg ambiant temp with a slightly bogged launch (I hate being too harsh on it) the factory figures say it should do a 14.2 so with a proper launch it should achieve that. This proves how healthy the car is.
It's time I bought a house so unfortunately the car has to go but I vow to return to skyline ownership bigger and better (do the words gtr ring a bell).
I live in Brisbane and while I don't have pictures of the car to show you I will drive the car to anywhere in Brisbane to give anyone who is interested a peek.
If your looking for a tidy unmolested skyline that are few and far between or a great base to modify from leave me a email.
https://www.sau.com.au/forums/topic/17828-series-2-r33-gts-25t-for-sale/
It may cost 18 - 19k to import a Spec II , but its not going to be the best example
Plus then you can add on the 3-4k compliance cost for a new RAWS compliance, and then add another 6-700 bucks for new tyres that are not usually included in the compliance cost... plus then you can pay for the 12 months rego that is also not included
Its all starting to add up hey.
So 25k for a nice clean example sounds about right to me, expect these prices to go up due for example :
In SA there used to be 80 Importers that had a licence to do compliance under the old system, now under RAWS there is going to be just 5 in SA... simular trend in other states... now you think the prices are not going to go up??
thanks the for the support guys, if you were to buy one from a dealer there would be a lot to spend on it as no used car is perfect. buying from someone who has maintained the car exhaustively (hence why i need to sell it, no money) makes alot more sense. it is still up for sale, regretably so as recently i went to willowbank to watch the production car championship and the guy that issues the tickets said nice car mate. also it got alot of attention because of its factory colour of metallic grey with a hint of rose in it. i thoroughly enjoyed the day and its these days a have second thoughts about selling it, i am ofcourse negotiable on price.
i meant that ppl with series II should be asking the $26000 etc that they are worth if it is a clean example. but its hard to stick with your value when ppl can import dodgy examples for $18000 etc and still want you to sell yours for the same $$$
no disrespect to you man, i was just saying stick to your guns.
same..
they r nice cars
i wouldnt go below 25 personally
sexy cars
i hate when people say
there worth 18 and shit like that
let them get one in for 18.. it would be one in suh a ****ed condition it wouldnt be funny
you get what u payed for
i baught a 1995 gtst for 23,000 people told me it was to much.. but.. it was the smoothest car i have ever driven and i have never ever had 1 problem with it.. and im happy what i baught
and it ran a 14.1 stock.. so im over da mood
http://members.optusnet.com.au/gregorydalton/Skyline/
i got that for $25,000 from autoshop, the cluthc lasted 200kms and thats without alarm and apline stereo(add another $2000)
clutch was $900 also.
autshop are bad. I had to get the colour thou.
  • 3 weeks later...
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
