Team Wang Vs Btr - Long Sleeve Shirts - Aug Deca
OK Ladies,
Ive been chatting with Corrinne (D_I_F) from Team NSW and she has kindly offered to organise long sleeve shirts for this upcoming DECA in August.
The design is as follows:
Vic Version:
The above design is a rough layout - final desing/logo sizes, etc will be posted by Corinne shortly.
Sizes are expected to range from S - XXXL.
Costs will depend on number of shirts ordered.
We hope to be able to have something like NSW in black and VIC in white, but need to hear back from printer.
Corrine will post more info as it comes to hand.
But for now.....who's interested???
TO ORDER - you will need to send Corrine (D_I_F) a PM to confirm order.
Cheers
BEC
  • Replies 46
Maybe on your guys vic ones you could have "its not the size of the logo that counts... its all in the timing of the WANG" or "power of the WANG"
or something equally as silly... that BTR thing is HUGE... obviously compensating for something
Yea sorry guys, I'm going to have the BTR logo resized so it doesn't oversize the wang.. :laughing-smiley-014:
So Yea, Any questions please pm me :(
Ok I've got a costing for the shit's they work out to be about $43 each.. The most expensive part of the cost is the set up fee's for the front side of the shirts..
I'm going to see what I can do to reduce these costs..
Im down for a NSW one. Only can i ask that we make the front left pocket area say SAU NSW, in a smaller size say 6-8 cm wide, then on the back have the large print that you show on the front? Also lose the Team BTR, should just be "BTR Beer Talk Racing"
Also, need to get approval from Boosted Zed, PORTS and Beer Baron before running off with their Track slogan... :)
Also before placing an order let me know where to email the verctor art image of the wang logo.
We don't want our wang's to be in poor quality now do we?
Also in! ... I like the small SAU logo idea from Bris (First and only time I will ever agree with him on the forums)
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
