hey guys. just wondering on what goes on, on resealing rear windscreen on a 32 cause the guys that did it before just took the seals out and just filled the gap in with sugaflex. now they are saying that the windscreen has to be pulled out then resealed. now i am just confused cause this was just a half finished job. could ya guys help me out here got the pic attached
thanks
https://www.sau.com.au/forums/topic/178304-windscreen/
yeah from da looks of things.... ur rite gonna have 2 pull it out and re-seal it....!!!!!
and da new moulding 4 da rear window is round da 500 bucks mark thats da complete seal kit genuine from nissan
im bout 2 re-do mine...!!!!
Please talk properly like your mum raised you to.
https://www.sau.com.au/forums/topic/178304-windscreen/#findComment-3254220
You can use another type of seal, I think it is an early CommonWhore item. Not to sure on the model, I will try and find out for you, However, the fit and finish will not look as good as a Nissan jobbie, I know, I have just done front and rear screens.....
Mike
P.S
That is a shitty half job, I would tell those rude bastards to pay for the R&R of the screen, seeing as they were so quick to take your coin, but then do a sub standard job.
And If they don't like what I have to say, tell them to come talk to me direct.... I like handing out pain!
Edited by MIKE_R32_GTR
https://www.sau.com.au/forums/topic/178304-windscreen/#findComment-3255927
    • What will you do when the Minister of War and Finance says the intake noises are too loud?
    • Will the clear coat dissolve the ink tho?? I thought about clear vinyl tape too. Thinking what to do haha. The one I have now is cracked in 1 spot, otherwise mint. Plus the MINES one is much thicker plastic material so its not flimsy at all.
    • No. Go a different colour, and just trim it at an edge line. Even manufacturers do different panels different colours etc.
    • I see no real downsides to ITB's, apart from the initial cost of my drive in drive out lifestyle, the "upsides" is they sound cool and would add lots of smiles I am willing to pay to play for the extra smiles I've spent the morning googling and youtubing the BBR ITB's, a "little" extra power and throttle response, but alot more dort, and really, I'm only really in it for the dort Who knows, after all this money is spent I might even make 150kwatw....LOL
    • With my block out to get honed, I'm just prepping all my auxiliary components in my mean time. I took my oil pump apart to inspect and repack it with assembly lube and either haven't noticed this in the past or found my answer and can't remember. What exactly is the regulator washer that the manual mentions replacing? I don't have one and from the manual it seems to seal the regulator plug to the housing but I can't see it on any pictures of new pumps either. Can anyone fill me in? I'm presuming this was phased out as I also can't find a replacement part in epc.    Image of a new pump. Can't see a washer there either.
