  • Replies 46
rich spikes, like excessive revs or something? please explain....
Na like when the bov vents, excess un burn't fuel will be dumped into the exhaust causing a backfire type sound. Not overly loud - also doesn't happen all the time either, mine doesn't really do it much at all, the turbosmart ones are good because you can tighten them up to increase the spring rate - hardening the piston in the bov to stop your car from stalling. If the bov is too loose i.e venting too much and or under idle it will cause you car to stall. If you are interested in the sound etc of a blow off valve then a pod filter will give you a simular sound just using the stock bov.
Basically set up right and you shouldn't have too many issues, but it may just cause your car to have those 'rich' as in rich fuel mixtures when the bov vents. nothing really to worry about. Try your bov and try adjusting the spring rate by turning the head of it, it should be fine, but if its causing you issues just wak the stock one back on and use a pod filter.
https://www.sau.com.au/forums/topic/178337-turbosmart-bov/#findComment-3254293
i have a hks pod filter at the moment... might have been better if i stated that i also have 550cc injectors, bigger turbo, fmic, walbro fuel pump, dump pipe into stainless 3 inch, microtech ecu ect.
it has an apexi (twin chamber) bov on the crossover piping at the moment but its not in use, it has the hoses of it but making the flutter sound it must be actulator, is that what is happening by the sound of things???
https://www.sau.com.au/forums/topic/178337-turbosmart-bov/#findComment-3254306
Sounds like your current bov is not working at all. If it were a working plambback you would get no flutter ans just a kinda cough out the pod filter. If your apexi was a workgin atmo you should get the flutter under lighter load conditions but then its venting sound at higher load. Does your current bov make any noise?
If it doesn't it may just be not a strong enough vacuum line going to the top of it. Sometimes if the vac line going to the bov has a tee piece in it and a hose going somewhere else as well, then it doesn't function properly becuase it fails to reconginise the change in manifold pressure.
Edited by R33silverS2
https://www.sau.com.au/forums/topic/178337-turbosmart-bov/#findComment-3254324
no, no sound comes out of the blow off valve at all, and yes it has a t piece, it should be to much of a change in pressure as the line has been kinked with a cable tie around it, blocking the boost controller, as my boost controller has been disabled. would it be an idea to totally remove t peice and hose to my boost controller?
https://www.sau.com.au/forums/topic/178337-turbosmart-bov/#findComment-3254403
Not totally sure how your setup is but, if the bov you currently have is in the stock position (just before the throttle body on the cross over pipe) It should have a single vac line running from the top of the bov and onto a the manifold (after the throttle body). Why is there a tee in the hose connecting to the top of the bov and where is it running to? I tee'd into it once before and the bov stopped working. So it needs to be a single line from the bov to the maniforld.
https://www.sau.com.au/forums/topic/178337-turbosmart-bov/#findComment-3254495
the tee piece near your air box etc won't have anything to do with the operation of the bov. Problem is i cant really see from that pic of the bov, where one of the red vac lines runs too.. the one furthest up the top looks like its running under the bov or is it connected to it as well? Where is that hose connected or does the bov have two hoses coming off it? A pic from the top rather than the side would be easier to see.
https://www.sau.com.au/forums/topic/178337-turbosmart-bov/#findComment-3254753
that looks like it should work. i'd say the piston is probably siezed in it.
oh ok, then maybe the bov is stuffed ir no good, because looking at the bov there is no tension screw on the top... arent the apexi twin chamber bov supposed to have the tension screw? if it is seized up is it possible to fix it?
https://www.sau.com.au/forums/topic/178337-turbosmart-bov/#findComment-3255071
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
