Hks T04z Vs. Trust 78
hey everyone
who can tell me which turbo to get for a nissan s13 silvia
the motor is a rb26 head with rb30 bottom end (not built yet)
the rb26 cylinder head
*head ported
*in/ex hks 280 degree 10.2 lift camshafts
*jun titanium retainers
*hks valve springs suit camshaft
*standard valves, 3 way valve angle maybee 4?
*tomei solid lifters
*hks metallic gasket kit
*cometic head gasket
*tomei cam cap studs
*arp head studs
*standard throttle bodies and plenum
*hks 1000cc injectors
*hks 11.0mm fuel rail, sard regulator
*hks adjustable cam gears
*hks cast iron low mount
*hks 50mm wastegate
bottom end rb30
*rb26/30 cp pistons
*billet argo rods i beam
*acl race bearings
*arp main studs
*ross balancer tuff bond
*n1 water pump
*jun oil pump, crank collar
*high energy sump 8.5l
i am capping the car at 800hp i doubut i can get it from pump fuel? but want to see the car at the drag strip with race fuel and slicks......just to brag 9's...lol
is the trust t78 better? i hear t04z has little lag
most of my things are hks so i'm leaning towards the t04z.... The cars goning to be a drift car and street drag car
what is the most rwkw's from this turbo
are all rated at 800hp? why get a bigger wheel ar100 if the smaller 1 ar63 is same hp rating?
thanks
josh
  • Replies 67
mainly drifting
it's going to be race prepped
cradle is going to be modified
with semi slicks
would the car just wheel spin, how about i turn the boost down for the streets?
Edited by ijoshi
If drifting is your main focus, neither of those turbos will be any good at all.
Too much lag and not enough response, peaky power delivery and poor throttle adjustability (important in a drift car!!!)
A few of the (expensive) parts/mods on your list would be over-kill for an RB30DET built to make a nice, responsive, 450 to 500hp- which would be more than enough in a light drift car like a silvia with the right suspension set-up.
I think you should look into it a bit more before going ahead with it.
I believe if anyone wants 800hp for drift and asking if you will get wheel spin thats a bit ignorant.
so cap it at 450hp - 500hp
would it have traction for the street?
and turn it up for when acting the fool....lol
is it possible to do this?
That's about the MAX you would want for a street car mate.
Like many have said, if you want a 'good' drift car, you're gonna need a responsive car.
But for which turbo to go ahead with? I would go the HKS T04z because it's newer technology?
hey
i got a hks cast iron low mount manifold
it has a t04 flange
and for the top it has a td flange 3 bolt for the wastegate instead put a turbo
my point is if i put a smaller trust td..... something (which one should i get)internal gate
and get a garett 3035r 700hp turbo d xr6 turbo also internally gated or smaller turbo?
then the car would spool up quick for drift and the big one would kick in later for drags
let me know ppl
Hoenstly mate, i think you really really need to do a lot more reasearch.
Your ideas sound very up in the air, let alone the budget.
Running a 400rwkw+ car is going to cost you upwards of 20k without even sniffing.
Probably closer to 30-35k by the time you replace everything you break when you try to start using the power
Yeah mate I really think you need to go back and have a look at the basic shit before youre doing what youre talking about doing...
Takes a lot of commitment and huge amount of cash to have a car running an engine like that...
Why do you think you dont see them everywhere? For just that reason, most people dont have the money, dedication, nor want to live with the compromise.
And I assure you, if you think youll be driving 800hp round on the street, there WILL be compromises :D
motor sounds like an overkill for a drift spec s13.
GT3540 or something similiar would be fine, atleast it would gain a bit of response over those other massive turbos you mentioned....
 Share
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
    • Id like to race in the US i think alot of those track would suit me   For the s15? Youd be stuck between club sprint and the new Open Am wouldnt you depending on how much interior you have left in
