hey everyone
who can tell me which turbo to get for a nissan s13 silvia
the motor is a rb26 head with rb30 bottom end (not built yet)
the rb26 cylinder head
*head ported
*in/ex hks 280 degree 10.2 lift camshafts
*jun titanium retainers
*hks valve springs suit camshaft
*standard valves, 3 way valve angle maybee 4?
*tomei solid lifters
*hks metallic gasket kit
*cometic head gasket
*tomei cam cap studs
*arp head studs
*standard throttle bodies and plenum
*hks 1000cc injectors
*hks 11.0mm fuel rail, sard regulator
*hks adjustable cam gears
*hks cast iron low mount
*hks 50mm wastegate
bottom end rb30
*rb26/30 cp pistons
*billet argo rods i beam
*acl race bearings
*arp main studs
*ross balancer tuff bond
*n1 water pump
*jun oil pump, crank collar
*high energy sump 8.5l
i am capping the car at 800hp i doubut i can get it from pump fuel? but want to see the car at the drag strip with race fuel and slicks......just to brag 9's...lol
is the trust t78 better? i hear t04z has little lag
most of my things are hks so i'm leaning towards the t04z.... The cars goning to be a drift car and street drag car
what is the most rwkw's from this turbo
are all rated at 800hp? why get a bigger wheel ar100 if the smaller 1 ar63 is same hp rating?
thanks
josh
https://www.sau.com.au/forums/topic/178356-hks-t04z-vs-trust-78/
  • Replies 67
If drifting is your main focus, neither of those turbos will be any good at all.
Too much lag and not enough response, peaky power delivery and poor throttle adjustability (important in a drift car!!!)
A few of the (expensive) parts/mods on your list would be over-kill for an RB30DET built to make a nice, responsive, 450 to 500hp- which would be more than enough in a light drift car like a silvia with the right suspension set-up.
so cap it at 450hp - 500hp
would it have traction for the street?
and turn it up for when acting the fool....lol
is it possible to do this?
That's about the MAX you would want for a street car mate.
Like many have said, if you want a 'good' drift car, you're gonna need a responsive car.
But for which turbo to go ahead with? I would go the HKS T04z because it's newer technology?
yeah i'll get the t04z
i want to convert the silvia to 4wd now
not right away though... i got a 300zx box an rbr26 bellhousing for now
its been done before
http://www.nissansilvia.com/forums/index.p...howtopic=224266
i'll give it a go... further down the track
thanks ppl
hey
i got a hks cast iron low mount manifold
it has a t04 flange
and for the top it has a td flange 3 bolt for the wastegate instead put a turbo
my point is if i put a smaller trust td..... something (which one should i get)internal gate
and get a garett 3035r 700hp turbo d xr6 turbo also internally gated or smaller turbo?
then the car would spool up quick for drift and the big one would kick in later for drags
let me know ppl
Hoenstly mate, i think you really really need to do a lot more reasearch.
Your ideas sound very up in the air, let alone the budget.
Running a 400rwkw+ car is going to cost you upwards of 20k without even sniffing.
Probably closer to 30-35k by the time you replace everything you break when you try to start using the power
Yeah mate I really think you need to go back and have a look at the basic shit before youre doing what youre talking about doing...
Takes a lot of commitment and huge amount of cash to have a car running an engine like that...
Why do you think you dont see them everywhere? For just that reason, most people dont have the money, dedication, nor want to live with the compromise.
And I assure you, if you think youll be driving 800hp round on the street, there WILL be compromises :D
    • Good to see your rotors appear as rusty as mine šŸ¤Ŗ
    • Took it for a drive to do some logs, Iā€™m pretty sure my voltage issues and electrical noise issues are gone, Iā€™ve sent a log to Adam and am waiting to hear back with confirmationĀ  att.K23U9eHyiEJxixH6y1__GQfuqK0EgIoDgQFTs9G8x_w.mp4 Ā  idle video from that day just becauseĀ
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!) Ā  Ā  I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding). Ā  I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springsĀ  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
Ɨ
Ɨ
