I never get why people come on here to tell people im going to put this and this on my car (copy and paste someones shopping list from another thread) and say they are putting it into their car and then ask a bunch of stupid questions when they obviously have no idea what they are talking about.
Seriously, do you kids have nothing better to do?
Shouldn't uz be touching urself to a cheap porno or something at this time of the night?
  • Replies 67
you guys keep bagging me out
you ask and learn......lol
:D
Its ok....you have a few posts...and 1 rating.... :(
It is always right to ask questions.....so you may learn.
But it is more important you read some sticky's...ie Turbo upgrades etc
before you ask a question about turbo choices etc..for a car you have built in your head.
i bought the silvia ca18de manual for $2500...lol
i bought the vl commodore for $300 ...lol ...cheaper than buying the motor alone
instead of buy a gtr i will put the money into this motor....makes sence
Did the VL come with a RB26?
Did the Silvia come with 4 Wheel drive?
You are going to build a 3L 1986 non turbo Nissan motor.......let me think...into
a kick ass turbo charged monster..then put it into a silvia..what year?....1994......
ITS CHEAPER BUYING A GTR...........
Its all good to be an individual...but the heart ache and the troubles you are getting in....OMG :thumbsup:
I want what you are on? :laughing-smiley-014:
gtr weighs to much....but adding this motor and 4wd system not sure how light the silvia would be
it will be unique....if i could go back i would
its a 1990 model silvia
GTR weighs too much.......you think that dropping a RB30/26 into a AWD nissan silvia will be much lighter?
The conversion has been done many times........on a RB26 motor..I believe SS or N1 turbo's where
used with a good set of cams (Tomie Poncams) to encourage response and mid range performance
and yes....forged and good bits where added to the engine for relaibility.
On a RB30DE..have never seen it done..let alone a Turbo fit......usually a Turbo motor is used.
Anyway...good luck with your project.
It wont be any lighter by an amount that would make such a thing at all worthwhile
you're going from alloy 4cyl to cast iron I6, plus all the associated AWD gear
complete woftam really. but would be a laugh if anyone could be bothered spending the time and moneh to do it properly
you've going from alloy 4cyl to cast iron I6, plus all the associated AWD gear
My thoughts exactly :thumbsup:
I believe Jay ran the T78 on his 2j in his cressida. Mild cams, plenum & exh. manifold.
That pushed out ~450rwkw. Not sure if that was on pump fuel, never asked.
That in no way looked laggy for such a big turbo; He said it used to come on strong a little after 4k.
Jay rana 10.1 @ 143mph with a manual. :glare:
Darrens R31 ran a 10.2 @ 140mph with a GT42/45 no transbrake and some where around ~450rwkw 2speed glide. That too comes on strong a little after 4k.
The mph's are good for a 9sec pass
hi guys
i need somone to confim this for me
i know a rb25 sump fits the rb30 block fins have to be cut down
will the rb25 gts4 sump fit the rb30...i know the rb30 will need bolts retapped due to larger gts4 bolts
the rb30's crankshaft is going to be knife edged....but i'm reconsidering it
it will be linched otherwise....due to the lighter pistons/rods....
i hear the 4wd sumps are no good on circut cars etc.
and people use dry sump set ups
its gonna acost around $1000 for a good oil pump $900 for larger sump
thinking of using morosso dry sump accessories
has anyone seen a tread or site on how to set up a dry sump?
please answer top question
i heard that the hks t04z version has a special exhaust valve for quicker spool time
the garrett one doesn't have this
any one hear about this?
Yeah it has a xenon push pull spool up valve you connect to your nitrous bottle. When you hit boost it opens the screamer pipe. Great for doing burnouts during the school holidays.
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
    • I wonder if these would be discounted when they have their big sales? because if so would be a great time to actually buy them could even end up cheaper than buying from quickjack in the end.
    • Which grit sand paper did you use on the pulley btw? Thought I'd ask so I don't scratch it up too much
