  • Replies 67
hi guys
i need somone to confim this for me
i know a rb25 sump fits the rb30 block fins have to be cut down
will the rb25 gts4 sump fit the rb30...i know the rb30 will need bolts retapped due to larger gts4 bolts
will this rb25 gts4 diff fit the rb30
or will the crankshaft hit the 4wd shaft inside the sump?
this guy knows f**kall and wants a car like this... he is 22 and would rather spend $30k on a car than something more important like maybe a house.. and a few k here and there on a car
Josh.... think about what your doing... ur an idiot
is the flux capacitor fluxing ?>
name = i-joshi
on another note, this was a gold call: + for part of new sigy
Shouldn't uz be touching urself to a cheap porno or something at this time of the night?
Edited by gts-4 dreamer
I dont see why comments like these are nesseary, his just asking a question and trying to learn.
Choku_Dori - Do you know all the answers?? I didnt think so. I reckon it would be interesting to know.
If he wants to spend his hard earned cash on a car its entirely his choice.. somepeople may not agree but there is no need for name-calling.
Josh - good luck with the project mate.. I think you should consult Harris Engineering on your project and get some real feedback.
John
name = i-joshi
Hahahahaha cheers mate :)
i heard that the hks t04z version has a special exhaust valve for quicker spool time
the garrett one doesn't have this
any one hear about this?
Don't know about any special exhaust valve but I do know the HKS T04Z has an anti-surge housing or as some people call them "speed holes". Gives it a nice whistling sound like the T51R but actually harms spool up by as much as 500rpm.
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
