By DraftySquash · Posted
Thanks @GTSBoy - I will see if I can rotate it. The problem is that the cover hits the circular pillar that holds the 2 valves - so unless I pull the piece out, it might still hit it. @Kinkstaah Yes I did take all the bolts off 🤣 When I first saw this cover, I thought to myself "Oh I have not seen this in any videos, but how smart!! It keeps any junk from going into the coilpacks" Pretty soon, I reverted my thought 😅 Worst case scenario, I'll take it down to a mechanic to have the spark plugs changed for me. But I will ask them to keep the old spark plugs around so I can ake some pics -
Oh I just meant the cloudly lens covers but if I can improve them in other ways I'm super keen! I know they're hard to separate though. On a second note, I have a small and sharp clunk in the front drivers suspension. Everything in there is new (M3 control arms, new sway bar, sway bar end links & coilovers) except the tie rod ends. I'm wondering if a bad tie rod end ball joint will clunk?
Something a little different.... Assembly videos of DeAgostini's 1/8 scale Fast & Furious BNR34 Nissan Skyline GT-R. Starting from issue 28 as the original intention was to obtain all 110 weekly issues then do a 'super cut' video. The boxes were taking up too much space so we start from #28:
Hello. Was wondering if having a dash cam is allowed in the car while tracking it?
It is actually a bit dicky to slide out. I'm assuming you removed all the bolts on it :p It does require a certain angle to go in/come out. When you line it up right you will see it will just slide out. You may need to take off the coupler for the throttle body to get the clearance. You may need to remove the engine cover's bracket as well. There's a fair bit of angles and a bit of twisting to get it to slide out which I assume is the issue here.
