just curious! on your boost guage what does it vacume at on idle?mine is around 18-20 psi ,which would say quiet good no?and also 18-20 wud mean no leaks at all?In old motors 18 vacume was good.
If your is different please post it :P
p.s i think my cheapo boost gauge says 13 psi when it is actually around 11?
if you have wrong reading with guages please post back also :D
https://www.sau.com.au/forums/topic/178421-im-curious-whats-your-vacumeon-idle/
wow hold up.. 18-20psi on idle??
or am i reading your post totally wrong..
Mine is like negative 0.7 bar.. at idle.. that means its not on boost..
.7 bar is about 10 psi but that guage isnt very accurate if its the standard one?and 10 psi is weak i think?
and yes i mean 18 to 20 psi vacume at idle
Edited by cosworth1971
Its actually mmHG not psi when you are talking about the negative units on your boost guage. You can't really have negative pounds per square inch if you think about it.
But yeah mine sits on ~ -20 on idle.
Edited by Rolls
well i have tested mine so much i cna't find any leaks at all anywhere, and mine still only sits at 18" mercury at idle at 650 rpm and about 19-20 at 750 rpm.
Any common leaks to look out for, did a whole heap of test break clener, carb cleaner, smoke, pressure, all good.
Should be IN-HG not mmHG. Well, it is on mine anyway.
Oh ok cheers! I was gonna fu**ing say, how the hell people were getting -18psi!!! Both mine and my mates sit on about -0.6, -0.7 bar.
but u earlier posted and said ur aftermarket said -10(in-hg)psi (whateva)
and tha factory boost guage is just there to look pretty IMO and wont give u a good reading
Yeah aftermarket says -10psi, stock one reads about -0.7 bar which is equal to -9.8psi :thumbsup:
Nowhere near -18psi.
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
