Hey
Tried doing a search, couldnt find anything on the forums, and there is nothing under the DIY/Tutorial section.
Just installing an AVCR into a R33 GTST, and need the pin outs on the standard ECU to hook the AVCR up to.
AVCR Wiring:
Red = Ignition +12v
Black = Earth
Green = Earth
Grey = Throttle
White = Speed
Purple = RPM/Injector
R33 ECU:
ignition +12v =
Earth =
Throttle =
Speed =
RPM/Injector =
We need to know which color wires on the stock ECU these go to, or at least the PIN outs.
If the AVCR is new, and never used, settings are on default, will it run standard boost or will be need to adjust it to run standard boost?
If anyone has settings for an AVCR to run about 12psi(0.8bar), can you please post them up, that will be a great help.
Thanks in advance,
Abu
https://www.sau.com.au/forums/topic/178426-installting-apexi-avcr-type-r/
Ok I now have the pin outs! So that is alright.
Can someone tell me how to hook the solenoid and vac lines up and also the other little black box style device?
Also if anyone has any ideas on how to tune it, that will be great,
Thanks,
Abu
Make sure you mount the solenoid close to the turbo(s).
I put mine where the existing gtr factory solenoid was - and the response to the solenoid is not that great - closer to the turbos the better.
Edited by paulR32gtr
Thanks for your help man, will make sure I mount it close to the turbo!
Thanks,
Abu
