G'day,
Since I have no luck in finding stock airbox for R32 RB20DET to replace the pod fitler (without having to wait 10 days for nissan to get 1 from japan).
My friend suggested RB30 airbox thinking it would fit in R32, my question is, would RB30 airbox fit on R32? Or other airbox that would bolt on as well?
The reason I'm asking is, the 32 i'm buying has FMIC and oil based Pod fitler, in Victoria it's a no-no.
Cheers
Grant
https://www.sau.com.au/forums/topic/178431-r32-airbox-qs/
Not too sure about whether a RB30 air box would fit a R32, but have you tried looking in the For Sale section? Or maybe try your local wreckers. They should store some. If no luck there, post up a WTB thread in the WTB section.
https://www.sau.com.au/forums/topic/178431-r32-airbox-qs/#findComment-3255678
G'day,
Unfortunately, there is none available for sale at the moment, I asked all wreckers around melb, they said they're out of stock (one wrecker told me EPA is the main reason! I'm not surprised).
Nothing at for sale section at the moment, might have to ask Nissan to get me 1 (whole airbox assembly for $241 something 10 days delivery for anyone who would like to know.)
Anyone know of another airbox that would fit in R32? A R33 airbox with air intake?
Cheers
Grant
https://www.sau.com.au/forums/topic/178431-r32-airbox-qs/#findComment-3256269
Hey man
RB30 air box is completely differnt, there is no hope that it will fit into an R32.
They are the same/similar to a VN - VS Holden air box.
I have also been looking for an R32 RB20DET air box, but no luck yet.
Keep trying :yes:
Thanks,
Abu
https://www.sau.com.au/forums/topic/178431-r32-airbox-qs/#findComment-3256882
Hey man
Keep trying :santa:
Thanks,
Abu
G'day,
Thanks for the confirmation will tell my friend he is wrong.
The fitlers are the same as R32 right(pretty sure i've read fitler compitablity on some thread here)?
How much have you been quoted for complete assembly, I've been quoted around $220 and should i gave up and go to my local nissan dealer, i'd be paying $241- for complete airbox assembly delivered from japan (10 days wait), I might go to other dealer and compare prices.
Also best of luck in finding 1 mate.
Cheers
Grant :D
https://www.sau.com.au/forums/topic/178431-r32-airbox-qs/#findComment-3257736
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
