hey, my r33 gts (auto at the moment) is being weird. when i start it up when its cold and drive it pretty much straight away its REALLY slow in 1st gear, then when it changed to 2nd its normal. its like not enuff power is getting to the wheels or something. it doesnt rev up as quick as it wud if it was warmed up either. im guessing maybe fuel filter is jst really blocked. or fuel pumps out the window. it also has a weird idle problem, where it bounces quite violently between 700-1000 rpm when its cold, or when i go for a drive, then turn it off, then back on. it only does it for a few seconds so i dont think its a vaccum leak. any help would be great! thanks!
https://www.sau.com.au/forums/topic/178449-r33-problem/
yer i usually do, just the odd time im in a hurry lol. when i warm it up its fine, no problems.
im thinking for the idle problem, maybe fuel filter? im changing that next week anyway. maybe fuel pump or filter for the other problem too? like not enough fuel getting to the engine quick enuff. or even the oils too heavy for the cold? i dont know. lol never heard of anything like this.
with breather filters. they connect straight on to the rocker cover ay? rb25de.
cheers guys
https://www.sau.com.au/forums/topic/178449-r33-problem/#findComment-3255590
cheers mate. i usually let it warm up for a 2 or so min cuz most days i park on a slope. then i take it easy. thanks for the help.
im cleaning the throttle body, afm and that this week and getting a new intake pipe, breather filter and fuel filter change so shud b alright after that!
cheers
https://www.sau.com.au/forums/topic/178449-r33-problem/#findComment-3256563
once you have started your car, let it warm for no longer than a minute. then drive it slowly untill the temp gauge is normal. Not a good idea to be booting/red lining it when cold!
;) Why would you say no longer than a min??
https://www.sau.com.au/forums/topic/178449-r33-problem/#findComment-3259542
hey, does anyone know why my breather filter is making my car stall when its cold?
cheers
http://www.bebo.com/PhotoAlbumBig.jsp?Page...toId=5174144877
thats where my breather is on my rb25de, replacing the hose that used to lead into the intake.
plz help lol
https://www.sau.com.au/forums/topic/178449-r33-problem/#findComment-3268905
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
