hey all,
i recently bought a '95 R-33 Gtst and the previous owner said that he has a bottlecap wedged in the wastegate or something to increase boost pressure.
now, as far as i know the engine and turbo are all factory spec apart from a GFB boost atomic boost controller, it did have a HKS mushroom airfilter that i took off and replaced with the original airbox for legal reasons. when the car revved it sounded like it had an aftermarket BOV (followed by big flutter) when in fact it still has the stock one still installed, he told me that it was just the boost rebounding off the bottlecap hence making the flutter.
it still does it with the stock airbox but it's not as loud.
i'm assuming this isnt safe for the engine/turbo??
my boost gauge sits on the zero mark and i've been told that it should read below the zero before the turbo spools up into boost.
is this correct??
any help greatly appreciated as i'm new to the skyline community.
https://www.sau.com.au/forums/topic/178527-bottlecap-wedged-in-wastegate/
he means he's got the bottletop wedged in the return from the BOV. I had to do this to check to see if my BOV was leaking.
Just undo the return pipe and knock the cap out, this'll stop it fluttering and you'll get the response back from between gearchanges also.
Was it your BOV leaking?
I'm trying to locate an intermittent turbo leak which might be the BOV, although I've done the crush job on a second one I bought, and I still get the same occasional whistle.
I was going to remove the BOV completely and put a plate on temporarily to see if I still had the noise, but a bottle cap in the return pipe would be easier.
Mike
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
